Fuel Temp sensor?
Old Jun 9, 2012 | 12:01 PM
odebiyi's Avatar
Fuel Temp sensor?
I just bought a new fuel pressure regualtor for my 87 z31 300zx. I was under the impression that the fuel temp sensor would come attached with it but it didnt. Now I am having a hard time buying a fuel temp sensor it seems like no one sells them Name:  IMAG0087.jpg
Old Jun 9, 2012 | 07:43 PM
Welcome to ZDriver!
Do you NEED a new fuel temp sensor? If not, just unscrew it and screw it back in the new regulator.
Old Jun 11, 2012 | 09:03 PM
odebiyi's Avatar
The self diagnostic code was 41 which is fuel temp sensor. I cant find any, do u have recommendations?
Old Jun 14, 2012 | 07:26 PM
AZ-ZBum's Avatar
It does come with the FTS if you buy it from the Nissan dealer. But you didn't, did you? You should go return the POS that you bought and ONLY buy it from the dealer.
Old Jun 15, 2012 | 05:22 PM
odebiyi's Avatar
ur right, I'm on it
Old Oct 22, 2012 | 06:18 PM
Crx1989's Avatar
I recently had the error 41 code on my z. If you look at the picture, it looks like the connection is corroded. I measured mine and it was fine. I cut the old connector off and put a basic connector on it and poof problem solved.
Old Feb 22, 2022 | 06:58 AM
Z3186's Avatar
You cut the little metal piece that sticks out? I recently just had mine break off and am trying to figure a way to fix it without replacing the whole thing.
Desert Rat
Jul 20, 2015 01:37 PM
Kyle82
Jul 31, 2014 04:21 AM
steve
Nov 8, 2011 03:27 PM
Niku-Sama
Dec 22, 2008 02:24 PM
one_fast_300zx
Oct 10, 2007 12:43 PM
