Fuel Temp sensor?
1 Attachment(s)
I just bought a new fuel pressure regualtor for my 87 z31 300zx. I was under the impression that the fuel temp sensor would come attached with it but it didnt. Now I am having a hard time buying a fuel temp sensor it seems like no one sells them Attachment 17518
Welcome to ZDriver! :006:
Do you NEED a new fuel temp sensor? If not, just unscrew it and screw it back in the new regulator. |
The self diagnostic code was 41 which is fuel temp sensor. I cant find any, do u have recommendations?
It does come with the FTS if you buy it from the Nissan dealer. But you didn't, did you? You should go return the POS that you bought and ONLY buy it from the dealer.
ur right, I'm on it
I recently had the error 41 code on my z. If you look at the picture, it looks like the connection is corroded. I measured mine and it was fine. I cut the old connector off and put a basic connector on it and poof problem solved.
Originally Posted by Crx1989
(Post 317824)
