engine problems
Old Apr 17, 2005 | 10:01 AM
keith'sZ's Avatar
engine problems
Wondering if anyone out there could give me any clue what is going on with my engine. I have a 86 non turbo automatic with 180,000 miles. Engine seems to run fine for first hour or two (normal operating temp, etc.) After that period of time engine will begin running excessively hot with what sounds like a valve pinging when engine is under load, idl is also sometimes affected but not much.
These are a list of things that I have done to engine.
Change timing belt
Water pump
Checked timing
spark plugs & wires
cap & roter
new thermostat
new radiator cap
cooling system flushed
air cleaner
Would greatly appreciate any ideas, thanks.
Old Apr 18, 2005 | 12:07 AM
s13z31killer's Avatar
Id suggest the cylinder head temp sensor. Its between the FPR and the AC compressor. It has a yellow connector. It takes either a 22 or 21mm deepwell socket.
Old Apr 20, 2005 | 08:49 AM
keith'sZ's Avatar
Thanks for the reply. Is this the coolant temp sensor or something else?
mad scientist
Dec 9, 2011 10:32 PM
MellowYellow300
38
Oct 24, 2006 03:41 PM
pinkneyss
Mar 30, 2006 06:46 AM
sk8er_of_durand
19
May 13, 2005 11:47 PM
Z_For_Life
Aug 29, 2002 09:02 AM
