Engine problems - need help..
Old Mar 27, 2006 | 11:21 PM
pinkneyss's Avatar
I'm have problems with my Z, & don't have a clue where to begin to fix it. It will start up and run fine for a while (usually about 30 minutes) but then after a while it wont run right at low rpm. It will die at stop lights, then pops & backfires while I'm trying to re-start it. When I try to take off, it spits & sputters & backfires. I have to kind of slowly tap the gas to get it moving, if I give it too much gas it bogs & tries to die. Once I get it moving & get the rpm up a little it smooths out & runs fine until I slow back down. Anyone have any ideas?
It's a '80 without turbo. In the last 6 months I've replaced the injectors, fuel pump, ignition module, plugs & wires, and the coil. Any help would be greatly appreciated!!
Old Mar 28, 2006 | 12:31 AM
skittle's Avatar
Taste My Rainbow
Sounds like whats happening to mine. Try replacing the AFM. Thats what i was told to do so when i get back i'll do just thats to see what happens.
Old Mar 28, 2006 | 04:17 PM
lifegrddude's Avatar
Externally Wastegated
Maybe a bad water temp sensor or corroded connectors? Sounds like the ecu is dumping in a lot of fuel.
Old Mar 28, 2006 | 06:07 PM
jfairladyz's Avatar
What year is it?
Turbo or Non-Turbo?
Old Mar 28, 2006 | 07:19 PM
Zskyline79's Avatar
I know what it is I had the same problem it is the fuel pressure regulator located on top of the engine to the middle where the fuel rail is. Replace that piece of junk, I had the same problem took me a month of going to the junk yard and replaceing almost everything to get it running right.
Old Mar 28, 2006 | 09:06 PM
pinkneyss's Avatar
Thanks for all the ideas, I'll check them all out. I did find one thing today that caught my attention. I pulled the afm off to check it out & found that all the bolts that hold it to the bracket had fallen out. One of the bolts has a wire behind it that grounds the afm to the frame. With the bolt gone, it wasn't getting a good ground. Is it just wishful thinking, or could this possibly be my problem? I put new bolts in it & I'll be driving it tomorrow to see what happens.
Thanks again for all the help!!
Old Mar 28, 2006 | 09:10 PM
pinkneyss's Avatar
Thanks Zskyline. That's what I'll try next if the ground wire wasn't the problem. Luckily I have 3 parts cars so I don't have to keep running to the junk yard & spending $$.
Old Mar 30, 2006 | 06:46 AM
Zskyline79's Avatar
yw I just remember how much of a pain it was before i found out the problem. Took awhile but i got it but luckly you have the parts there me I had to search and search hehe.
mad scientist
Dec 9, 2011 10:32 PM
MellowYellow300
38
Oct 24, 2006 03:41 PM
MarkieMark
Aug 29, 2005 05:54 PM
sk8er_of_durand
19
May 13, 2005 11:47 PM
Z_For_Life
Aug 29, 2002 09:02 AM
