electric issues...
i have a star wars dash....the problem with it is this... i have back lighting when i drive at night on the cluster and i have back lighting on the 2 gauges but what i don't have is any readings!!! i.e. i have no fuel, oil, temp, tacho, speedo, elec compass or the acceleratormatron thingo. I need this issue attended to as its not real safe to drive atm... The only other thing that IS on the cluster when the engine is running is the lights that normally come on when the key is turned to acc before the car is started. These lights stay on all the time!!! the only time they switch off is when the key is turned into the ACC postion.. HELP please...
I thought it was a fuse or somethin but i'm not good with electrics and have found NO burned fuses...
skupy
Nov 14, 2005 01:42 PM
