do z31 alarm systems kill the battery if they go on too long or do the shut off
Old Oct 27, 2006 | 02:42 PM
Turbo86's Avatar
do z31 oem alarm systems kill the battery if they go on too long or do the shut off in time ... I was working under my Z and I tripped the hood alarm by bumping and I went to go put the key in ignition and turned it off but I think it was still clicking or half going off but no sound or lights I shut the door and it seemed to be off but I went to my car the next day and the battery is dead so maybe it was still going or does it have a kill switch or something
Old Oct 27, 2006 | 02:50 PM
also, do z31's have an starter lockout?
Old Oct 27, 2006 | 04:16 PM
rogerz's Avatar
Grumpy & Helpful
Not sure about the auto shutoff but I do know they will drain your battery over time if you don't drive it every few days because it is always drawing a little current.
Old Oct 27, 2006 | 04:25 PM
Turbo86's Avatar
oh man I didn't know that It's been sitting for months while I'm working on it next time I disconnect the battery for extended times ... doh! ... oh well good excuse to get an optima red top ... this time I'll keep it unhooked
Old Oct 27, 2006 | 04:58 PM
Z Car Barbie's Avatar
User Friendly
If your battery is going dead, then it will trigger the alarm. Sometimes people assume the security system is what drained it, when it was actually just a bad battery to begin with. But, yeah, the alarm will continue sounding in intervals until the battery is completely dead.
Yes.
Old Oct 28, 2006 | 01:22 PM
Turbo86's Avatar
is the starter lockout unarmed with the key in the door, ignition or some super secret hidden switch.
Old Oct 28, 2006 | 02:10 PM
User Friendly
When the key is in the ignition and turned to the ON position, it disables the starter kill switch. If you put the key in the door then lock and unlock it, that'll reset the alarm system, but not disable the kill switch.
Are you having problems starting your car now, or something? If so, and you recharged or replaced the battery, check the wiring to the starter. I know you were recently working on your car and might have accidentally disconnected a wire. It's easy to do, especially when replacing the oil filter.
Old Oct 28, 2006 | 10:52 PM
Turbo86's Avatar
well I haven't gotten a chance to replace or recharge battery yet ... that's my true problem I never get enough time to work on my car ... it's in really really nice shape though for 20 years old only 62,000 original miles ... at the moment my new 3" CM exhaust is in mid install waiting for me to come back to finish.
Old Oct 28, 2006 | 11:14 PM
my car would start just like any normal good running car would, except for one time i was backing in my steep driveway and stalled it, so i turn the key off, push the clutch and brake down, then hit the key and it does nothing, not even a click, plus i also disconencted this aftermarket alarm system and pulled the relay for the stock alarm..
Nforce1
Jul 18, 2005 09:35 AM
93TTZ
Feb 28, 2005 07:09 PM
kolts
Oct 19, 2002 07:57 PM
1hot300
Feb 2, 2002 08:29 PM
TIGGERHALL
Jan 28, 2002 01:47 PM
