Compression test
Old Jun 15, 2012 | 05:27 PM
odebiyi's Avatar
Compression test
CYL#1 -111
CYL#2 -105
CYL#3 -104
CYL#4 -111
CYL#5 -138
CYL#6 -103
Looks like Cylinder 5 took a crap, I pulled the spark plug and it had coolant and oil on it. Looks like head gasket job, any suggestions on the easiest way to get the job done?
Old Jun 15, 2012 | 08:20 PM
AZ-ZBum's Avatar
Umm... Higher numbers is better. Looks like you're low across the board EXCEPT for cylinder #5. I think your rings are very worn out if all your numbers are that low. Looks like it's more than a head gasket. Looks like it's a full rebuild.
Old Jun 15, 2012 | 11:14 PM
If he found coolant and oil on the plug with the highest reading I think the coolant and oil sealed the rings more then usual which gave the higher reading. I would say check the head gaskets first, worst comes to worst he's already a step ahead if he decides to rebuild the motor.
Old Jun 18, 2012 | 08:35 PM
odebiyi's Avatar
Does anyone know what the normal compression numbers generally are for these motors?
Old Jun 19, 2012 | 07:02 PM
noboosts130's Avatar
Lurker
FSM for 87
Standard
NA 173
Turbo 165
Minimum
NA 128
Turbo 121
Differential limit 14 psi
Old Jun 20, 2012 | 06:47 PM
odebiyi's Avatar
Originally Posted by noboosts130
FSM for 87
Standard
NA 173
Turbo 165
Minimum
NA 128
Turbo 121
Looks like I'm doing a rebuild, thanks
3riCJbOi
Jan 16, 2012 11:06 AM
wild_maxx
Oct 8, 2006 12:32 AM
speedgato2
Jan 12, 2004 08:57 AM
86ZXTurbo
Jul 17, 2003 01:36 PM
Zwolftech
Apr 24, 2002 06:05 PM
