Compression test
CYL#1 -111
CYL#2 -105 CYL#3 -104 CYL#4 -111 CYL#5 -138 CYL#6 -103 Looks like Cylinder 5 took a crap, I pulled the spark plug and it had coolant and oil on it. Looks like head gasket job, any suggestions on the easiest way to get the job done? |
Umm... Higher numbers is better. Looks like you're low across the board EXCEPT for cylinder #5. I think your rings are very worn out if all your numbers are that low. Looks like it's more than a head gasket. Looks like it's a full rebuild.
Originally Posted by AZ-ZBum
(Post 312323)
Does anyone know what the normal compression numbers generally are for these motors?
FSM for 87
Standard NA 173 Turbo 165 Minimum NA 128 Turbo 121 Differential limit 14 psi |
Originally Posted by noboosts130
(Post 312513)
FSM for 87
