Chts
Old Sep 24, 2005 | 04:09 AM
shawn86t's Avatar
Chts
Engines just going back together, stopped for a day since i broke an exhaust stud and i dont have my easy outs at the moment, so i decided to run some tests, pulled out the CHTS, and chucked it on the multimeter, FSM says a general reading of 2.3 to 2.7 ohms is good, through my heat test my dropped to 1.70 ohms at around 140 degrees and cold at 2 degrees showed up as 3.7 ohm, im guessing its stuffed.
So i rang around today trying to find a new CHTS. With no luck all i could find was one for 80 dollars, and for 80 dollars, i'd hope it'd never break again in my lifetime.
i came to the conclusion that perhaps people didnt quite catch on when i said Cylinder head temp sensor, so i'll ring around tommorow saying "Coolant temp sensor"
Ahhhh the joy of living in australia.
Also just a personal note, the heads on my z31 for 160k km were in really bad nick, i had to reseat and reface the valves and seats, replace all the studs now and i really wish the heads were built as good as the bottom end, which may i add, still had the factory cross hatch hone marks in the bore and the bearings wer un marked. still did the works tho.
Old Sep 24, 2005 | 05:20 PM
AZ-ZBum's Avatar
http://www.az-zbum.com/information.common.parts.shtml
Old Sep 24, 2005 | 11:17 PM
shawn86t's Avatar
Cheers mate.
Old Sep 25, 2005 | 03:00 AM
AZ-ZBum's Avatar
no worries... just keep the VB cold for me...
Old Sep 25, 2005 | 05:32 AM
shawn86t's Avatar
lol nice, will do
John300
Feb 17, 2013 04:02 PM
anniversary_Z
May 5, 2011 02:40 PM
mrbillishome
Mar 10, 2010 07:20 PM
drfrankenstein
Apr 30, 2007 08:49 PM
Carl's Z
Feb 26, 2007 08:43 PM
