Chts
Old Feb 18, 2010 | 08:36 PM
mrbillishome's Avatar
Chts
In the middle of rebuilding my heads my wires for my CHTS broke right at the connector. Now thinking about it its just a thermisitor so i cant really repin them backwards because it would send back the same signal no matter how it is connected. Correct? lol Please and Thanks for the input.
Old Feb 19, 2010 | 08:51 AM
This is my personal preference, but if the connector broke, I would grab another one from the junk yard & spice it in correctly. Nothing like jimmy-rigging a wire & then two years down the road, forgetting if you crossed the wires or not...
Old Feb 20, 2010 | 08:29 AM
rogerz's Avatar
Grumpy & Helpful
it is the same as a fuel injector connector which are available. do a google on it. there is an autozone number posted on one of the forums. you can just eliminate the oval one atop the engine just another failure point might as well do a good solder and heat shrink job. It is there as a maintenance nicety for the dealers but since we work free on our cars get rid of it. sits up there soaking up heat. if not that try z man of washington I'm sure he has them or at least a source.
Old Mar 6, 2010 | 09:26 PM
my86z's Avatar
No, the CHTS connector is slightly different. However, I did modify one to work with the injector clip. Just remove the raised area on the back side of the CHTS. That way it won't prohibit the injector connector from fitting.
Old Mar 7, 2010 | 04:34 PM
Well my problem actually lies in the wiring of it. Im wondering if it really matters how i wire it back up.
Old Mar 7, 2010 | 08:17 PM
my86z's Avatar
Doesn't matter. It's just a variable resistor (temp activated)
Old Mar 9, 2010 | 06:22 AM
All righty thank you now all i have to do is put my engine back in and the z is back on the road!
Old Mar 9, 2010 | 06:54 AM
TeamRonin's Avatar
How would you replace CHTS with the motor in the engine bay? I believe mine needs a replacing. That animal looks very hard to get too. Especially how am i gonna remove the clip with the back plate of the timing cover in the way?
Old Mar 9, 2010 | 08:50 AM
its a pita but once you get the clip off you can easily hit it from the front with an extension, once you have removed the ac idler pulley and fan. just remeber it is at an angle in there so come from the pass side at an angle on the front bumper
Old Mar 9, 2010 | 10:33 AM
TeamRonin's Avatar
Thats a tight squeeze! what socket did ya use? im afraid ill break the clip. How did ya get the clip back on? thanks
Old Mar 10, 2010 | 07:20 PM
i just used a regulat thin walled 3/4 if i remeber correctly and i had to figit to get the clip on and off also
John300
Feb 17, 2013 04:02 PM
anniversary_Z
May 5, 2011 02:40 PM
drfrankenstein
Apr 30, 2007 08:49 PM
Carl's Z
Feb 26, 2007 08:43 PM
shawn86t
Sep 25, 2005 05:32 AM
