86 z31 wiring and code help
Old 07-03-2007, 05:11 PM
cinpro's Avatar
Question 86 z31 wiring and code help
car info
86 z31 non-turbo manual transmission digital dash, the car has been sittng for about 2-3 yrs before we got it.
when we picked up the car it was running okay, nothing out of the ordinary ( I wasn't pushing it or anything , my main concern was getting it home)
what going on at this point
the car turns over, but either does not start or will start after many tries.
I located a repair manual (Haynes) and found there are codes to be retrieved and how to read them. when I turned on the car it gave me the two codes, 31 and 23 (not 24). from there I tried to start it. and got the code for the air flow meter (code 12-[ MAP sensor the modern name?]) when I pulled out the the sensor to inspect it I found one of the screens ripped to shreds. I also found some cut wires, I don't like cut wires when I don't know what they're for.
this is near the MAP
passenger side right behind the head light this has power to it
theres a vacuum hose that doesn't appear to have anything to attach to here
and couple of things that I want to know if they look "normal" it been awhile since I did any real mechanic work so take it easy on me I'm trying to get back in the groove.
I believe this is the EGR, is that screen normally open?
also all the pictures in the books show the coil over close to the drivers headlight, it looks like its in it home spot right by the distributer. theres are also a couple of connectors that appear to have nothing to plug into. there is one the right in this pic.
and this one looks just like the one for the O2 sensor but the with different wire colors
speaking of wire colors are there better wiring diagrams than the ones in the Haynes manual available?
so if some one can point me in the right direction that would be really cool. I don't get much time to work on it and want to make the most of my time. and thinks for yours.
cinpro is offline
Old 07-03-2007, 08:51 PM
Goofyz's Avatar
What's the smurf tube for
what's in that blue smurf tube?
Goofyz is offline
Old 07-04-2007, 01:15 PM
cinpro's Avatar
Do you know just how many Smurfs we had to skin to get that !? lol
its just there since what was there crumbled like paper when we went looking for the other things that needed to be connected. It was cheap fix till everything gets worked out then I'll worry about cleaning it up, it's just going to get messed up anyway while work is being done.
cinpro is offline
Old 07-09-2007, 03:23 PM
cinpro's Avatar
boy this place is dead
cinpro is offline
Old 07-09-2007, 07:18 PM
Distinquished Guest
johnZboy's Avatar
Cool Oh My!!!
R.I.P.
Looks as though that z31 is dead, too. Somebody has been clipping a few wires, for sure.
Sounds like you're on the right path (Haynes manual and running the codes).
The MAF is probably fried. Go get one from the "Pick-n-Pull".
The screen on the EGR is suppose to be open.
Those two connectors probably connect to heat sensors. There's one on either side of the lower intake. One works the dash gauge, the other feeds data to the ECU. If the sensors are still there, the plugs will match.
Everything else is a crap shoot. Good luck.
johnZboy is offline
97gtp
07-31-2014 09:18 PM
Nick Napala
FS: 300ZX (90-96)
02-07-2014 01:55 AM
jeff1986
06-29-2013 09:56 AM
3riCJbOi
09-22-2009 11:10 PM
Green96TT
06-28-2004 02:25 AM
Quick Reply: 86 z31 wiring and code help
