86 reverse lights!
Old Mar 19, 2014 | 03:42 PM
Zsteve's Avatar
86 reverse lights!
My reverse lights are on all the time, except when I turn the car off... I never experienced this one before!
Can anyone help?
Thanks!
Old Mar 19, 2014 | 04:28 PM
rogerz's Avatar
Grumpy & Helpful
switch that turn them on is in the tranny if you have a stick. auto I don't know. it is stuck closed
Old Mar 19, 2014 | 04:37 PM
zxguy1986's Avatar
Zsteve, I have a related prob with my '86T (my reverse lights do not work at all - bulbs/circuits are OK). Let me know what you figure out and I would appreciate the input. I have not looked into the harness hookups with my tranny (5-speed) but as rogerz says, the prob is likely there. Can't think of anywhere else it could be.. So it sounds like a good few hours of work to get in there, trace down the prob - fix it and get out again. Let me know what you do with yours. Thanks!
Old Mar 19, 2014 | 04:44 PM
Zsteve's Avatar
I have a 5-seed. O'boy! I have to pull the tranny? I unplugged the light's for a quick fix! I obsess when my car has probs...lol
Old Mar 19, 2014 | 04:48 PM
Zsteve's Avatar
I will for sure! I've had more problems with this Z than, I have had with any of the others I have owned.
Old Mar 19, 2014 | 05:09 PM
zxguy1986's Avatar
rogerz didn't say - but my guess is that the harness links to the tranny would be interior - meaning inside the cabin - over the top of the tranny somewhere around the base of the shifter, in front of it or in back.
Unless rogerz sends a DON'T DO THAT msg, I would start by taking off the console and digging around. Got to be a harness link with circuits you could test. Underneath would be a major pain.
Let's wait for rogerz' input. He has obviously thought about this.... and he's chronically opposed to wasted effort.
Old Mar 19, 2014 | 05:34 PM
zxguy1986's Avatar
OK, but I can't throw out the baby that easy. Thrown babies cost $$$. All I really need is clean bath water.
Old Mar 20, 2014 | 08:26 AM
zxguy1986's Avatar
Found the reverse lamp switch in the FSM, schematics MT-2 and MT-20. Looks like you would put the car on a lift and check the switch out. It's on the side of the tranny toward the rear and it's either dead or disconnected.
Old Mar 20, 2014 | 10:31 AM
rogerz's Avatar
Grumpy & Helpful
you can get to it if you put the car up on jack stands. not need to pull tranny. check for power to the switch. if no power then dive into the schematics or run a new wire. you may even find the connector hanging in the air unplugged.
Old Mar 20, 2014 | 11:16 AM
Zsteve's Avatar
Thanks, I looked at my other tranny, and seen the plug! So I jacked the car up, unplugged it, the lights went out!
I removed the used one and replaced it. It's working fine now!
Thanks again! 15min fix
Old Mar 20, 2014 | 02:06 PM
zxguy1986's Avatar
Quick fix! We all look smart again.
Old Mar 20, 2014 | 04:22 PM
PredatorZ's Avatar
woot
Way to go, nice fix
Greg79
Oct 8, 2011 08:10 AM
tonsoffun300zx
Mar 11, 2008 02:19 PM
ceZar veleZ
Mar 29, 2006 11:10 PM
Shameless
Apr 26, 2004 09:47 AM
Shameless
350Z Performance / Technical
Jan 4, 2004 03:48 PM
