86 na to turbo conversion
Old Sep 15, 2007 | 08:02 PM
asswho's Avatar
Ok i was wondering if all the info i got was right, im going to go from the NA to turbo i have all the parts, i was told that if i turbo the na motor that the stock internals and heads will do just fine, and i was told that i didn't need to change my harness, but that i could not run my stock injectors, i have the turbo injectors from a 86 turbo, and was also told that i had to specifically use a 86 turbo ecm. Is this true and will the turbo ecm plug right in to my na harness? any guidance would be very helpful.
Thanks in Advance
Old Sep 16, 2007 | 02:50 AM
entropy31's Avatar
The Cake Is A Lie!
while the NA motor CAN be turboed, it is not recommended, as the compression ratio is significantly higher. you will be limited to a rather low level of boost. NA-Turbo is the #1 asked question on this forum, search around a bit, as there is a wealth of info on the subject.
Old Sep 16, 2007 | 09:08 AM
z-hag's Avatar
Queen of Yachts
works best to just buy a turbo z in the first place-----they are cheeeeeep enuff--i found one for 200$--you can , too--why screw up a perfectly good na with a turbo conversion that will not do any favors for the engine????and cost you many dolla?????? think smart----buy a cheeep turbo and fix it up.......
Old Sep 16, 2007 | 09:51 AM
asswho's Avatar
what
i have heard that the na to turbo can go horribly wrong but im not real sure if i care, here is the story unless i use/sell these parts my wife wont let me get anything else. But if they blow up i have no other choice. I really want to do a v8 (infinity) but now i have to many parts
Old Sep 16, 2007 | 12:04 PM
Just out of curiosity... who is telling you all this?
cerealkilla
Jan 11, 2004 03:27 PM
79GS130ZL
Oct 11, 2003 08:36 AM
79GS130ZL
Aug 30, 2003 12:24 PM
280 drooler
Jun 18, 2003 10:15 AM
Destrega
Jul 15, 2002 02:13 PM
