Timing belt
Old 06-20-2011, 02:08 PM
87z
87z's Avatar
Timing belt
Hey guys I just changed my timing belt and all other belts and I put it all bak together and now it won't start. It cranks but won't start. Anyone know what's going on?
87z is offline
Old 06-20-2011, 02:18 PM
Yeah, you ****ed something up and now it won't get one of the three basic essentials for a car to run.
hoov100 is offline
Old 06-20-2011, 03:37 PM
HexaggramJDM's Avatar
Please dont crank your motor anymore.. (like it matters) .. the all "VG" motors are Interference motors.. which means the valves can and will hit the Piston if it skips a beat or snaps... I would say check all your sensors and fuel pump to see if they are working.. if they are...Remove your heads and check your cylinders and valves for damage, if there is none, ECU replacement is in order...
HexaggramJDM is offline
Old 06-20-2011, 09:39 PM
87z
87z's Avatar
I need a new ecu? Really I don't really know all that much about these cars yet. The sensors are all fine tho
87z is offline
Old 06-21-2011, 03:59 PM
again, If your sensors are connected and working and if your fuel pump is sending the correct PSI of fuel.. and if Your heads are not damaged, then its the ECU. I also forgot to mention to Check your vacuum hoses.
Old 06-21-2011, 08:10 PM
Grumpy & Helpful
rogerz's Avatar
if it ran before you changed belts then the ecu is fine but you screwed the pooch big time on the timing belt (probably). or you pulled a wire loose that you didn't notice during the dissasembly/assembly process.
rogerz is offline
Old 07-06-2011, 05:12 AM
EZee's Avatar
I'd start by verifying the timing marks to make sure the installation is correct. If it is, start checking for spark, fuel, and air.
EZee is offline
Old 07-07-2011, 07:26 PM
87z
87z's Avatar
Still not right
Ok well I ripped it back apart and redid it all an now it starts and runs. But when I took it for a test ride it wouldn't pull at all. It was like as soon as the turbo starts to whistle it starts bogging out with the more gas I apply. I would guess boost leak somewhere?
87z is offline
Old 07-16-2011, 02:02 PM
87z
87z's Avatar
Also I noticed that it idles a little low. And it will go then kinda big out then will go again and continue this the whole time im driving it. I checked for vacuum leak and replaced a few old lines but still does the same. Any help would be appreciated
87z is offline
Old 07-18-2011, 12:31 PM
87z
87z's Avatar
Well since I stopped getting help here I tried taking it to a local foreign car shop and they refuse to take it? Yea kinda weird to me being that they are supposed to specialize in cars like that
87z is offline
Old 07-18-2011, 02:24 PM
West Coast!
tonsoffun300zx's Avatar
sometimes it's just not worth there time and if thats the case you may have to take it to nissan.
tonsoffun300zx is offline
Old 07-18-2011, 07:49 PM
Monkies's Avatar
My Nissan dealership will not touch any z31s I was picking up some parts and I saw this guy with his z31 and asked him about it and said they wouldn't look at his window motor, and I got the same kind of response about my dashboard (before I got it fixed). That's some stuff there......
But back to the OP, I'd be looking at the dizzy with a timing light gun thing (the name of it escapes me). Does it idle fine? What happens if you rev it up in neutral?
Monkies is offline
Old 07-20-2011, 04:28 PM
87z
87z's Avatar
Thanks for the replys. Yea idk why no one will work on it but it's whatever. And I just fixed it today. The timing was pretty far back. I actually just got done my test run and it runs the same as when I bought it if not better. But it did idle fine just lower than before but it would idle at 1000 before and is about 650 which is stock anyway. It also would rev fine with crappy throttle response.
87z is offline
Old 07-20-2011, 04:55 PM
87z
87z's Avatar
I still have the starting problem tho... I have that on another forum if anyone knows anything about it. I already replaced relays clutch inhib switch and checked starter and no change an also is worse when either motor is hot or it is hot outside
87z is offline
Old 09-13-2011, 01:14 PM
AZ-ZBum's Avatar
You put it back together wrong. Plain and simple.
Take it back apart and figure out where you screwed up.
AZ-ZBum is offline
Z Pal
01-09-2015 02:35 PM
ieatmustangs
09-25-2012 04:19 PM
GWC300ZX
04-27-2003 02:44 PM
pretender84
07-27-2002 08:28 PM
rngrck
02-08-2002 10:18 PM
Quick Reply: Timing belt
