Starting problems
Old Feb 14, 2010 | 06:08 PM
TeamRonin's Avatar
Starting problems
When i try to start up my 88T car comes on for a second and goes off. I really have to pump the pedal quickly to try to keep it going. Then it will sputter and die. To get the car started it will take almost a quarter tank of gas plus it will take a total of roughly 15 mins to get it going until it warms up and then it runs like a freakin CHAMP! then when i turn it off, it goes back to the same problem again.
Im thinking Fuel Pressure Regulator and TPS but i wanna be sure though before i go blowin money i dont have. This is why. I already checked fuel pressure and its at 40psi, Fuel filter replaced with a WIX, cap, wires, plugs, and rotor. Im also idle'n at about 1100 rpms. It should be at 700 rpms. correct? Idle'n has always been a problem.
Oh! And i also noticed that when i took the plugs out, they are pretty wet. When i dry them and plug em in, it fires up nicely. What do yall think?
Old Feb 14, 2010 | 07:36 PM
Pull the ecu codes.
Old Feb 14, 2010 | 08:42 PM
TeamRonin's Avatar
okay I hooked it up to the computer and it stated the coolant temperature sensor is bad. but would that affect my excessive use of fuel and complicate my start up? that's all it read.
Old Feb 15, 2010 | 08:15 PM
I would start by checking that.
Old Feb 17, 2010 | 11:08 PM
rogerz's Avatar
Grumpy & Helpful
probably the cylinder head temp sensor (may be what you are calling the coolant temp sensor) but it isn't. It is the usual problem when it runs fine warm and won't start cold. Do a search on how to replace there is a write up on the web. Pretty cheap under $40 part.
Old Feb 18, 2010 | 01:18 AM
TeamRonin's Avatar
just got the part in last night in (fuel pressure regulator) and i will be installing that this morning. so i'll keep ya updated on that and as far as the head sensor i need to put that on order. i was told that sensor does play a vital role in engine start up and plays a factor in fuel consumption. so indeed plan to replace that especially when the computer is picking it up.
Old Feb 18, 2010 | 01:22 AM
TeamRonin's Avatar
oh yea where the hell does that head sensor install at? from what the diagram says its behind the right hand side camshaft but i dont see anything or any wires in that general area. Any one help me out on that? Just need a location where to install it and plug it in. thanks guys!
OsidonZ31
Mar 10, 2014 12:47 PM
300zgearhead
Jul 21, 2010 04:04 PM
KasbeKZ
Jan 17, 2009 05:10 PM
Stubby
May 7, 2005 11:18 AM
Blockmaster
Aug 2, 2002 01:55 PM
