Replacement Fuel Level Sending Unit
Old Sep 2, 2015 | 04:34 PM
mgk1068's Avatar
Hi, has anyone tried the replacement fuel level sending unit from Nissan? No matter how I configure it, the needle bounces all over the place. I can see now why the old one has the cylinder around the float.
Has anyone else experienced this?
Thanks
Old Sep 2, 2015 | 05:01 PM
zxguy1986's Avatar
Yes. Fuel level sending gadget is a frequent problem with the Z31s. In my original '86na, two or three times I cleaned the wires that the floaters rode up and down but that only postponed the problem and my fixes didn't last that long. Maybe a year.
Finally bought an aftermarket replacement that I didn't adjust correctly so it always read about 4 gallons too low. For replacements, I think either aftermarket or OEM where available would be OK but you have to adjust them by installing the gadget, getting a reading and then moving the reader/sender gauge either up or down as required. You want Betty to tell you that fuel level is low without driving you crazy.
Anyway, a bouncing needle is a hint that the sending unit isn't working right or you have a bad/dirty harness circuit between sender and gauge. Check all that out before you replace the sender. Again.
Old Sep 3, 2015 | 01:11 PM
rogerz's Avatar
Grumpy & Helpful
replaced one digital and one analog no problems with either one. as zx said check your wiring.
Old Sep 3, 2015 | 04:40 PM
rogerz's Avatar
Grumpy & Helpful
what did your replacement look like. The replacement that works has floats that work arms to send the signal. the old style Iron bar with carbon tracks inside an aluminum can are no good. where did you get the "replacement"?
Old Sep 4, 2015 | 11:02 AM
mgk1068's Avatar
Got it from Nissan. It's the factory replacement.
Old Sep 4, 2015 | 11:03 AM
mgk1068's Avatar
I don't think it's the wiring because the old gauge didn't do this. It just said the tank was empty when it got down to half. The needle didn't bounce around.
Old Sep 5, 2015 | 08:01 AM
rogerz's Avatar
Grumpy & Helpful
that link goes to ebay often a source of junk. try courtesy nissan for a REAL nissan part not ebay factory replacement part which means someone made it in a factory and then said it is a genuine replacement
Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com
I think you bought a faulty or at least non standard replacement. get a refund
There is nothing TO CONFIGURE with a real part.
Old Sep 5, 2015 | 08:18 AM
mgk1068's Avatar
Thanks roger. I actually ordered it from my local Nissan dealership, part # 25060-17P65. I
didn't post a link.
houlis1211
Feb 24, 2013 07:04 PM
HexaggramJDM
Jun 29, 2011 10:37 PM
rjc280z
Sep 29, 2009 01:13 PM
Carl's Z
Sep 12, 2005 04:53 PM
ratedZ
May 26, 2001 07:58 PM
