Help! 86 z31 starts but bogs down on acceleration
Old Feb 5, 2017 | 05:52 PM
z311986's Avatar
Hello everyone. First post here. I've had an 86 z31 for almost 3 years now. Last week I was driving to work and it stalled out in the middle of a long bridge. Not fun! I was unable to start it at first. After being towed to a garage it would start again. The mechanic noted that 2 fuel injectors were leaking. I couldn't afford the $800 to fix so I did myself. Now it will start but is very sluggish. Undrivably so. Everything seems to be reconnected right. I also replaced plugs and wires. I am at a lost as to what caused it to stall in the first place and why I can't get any power out of it. I need the car for work and am poor as a church mouse during the slow winter. Any help would be great. Thanks.
Old Feb 6, 2017 | 07:07 AM
Welcome to ZDriver!
Start by pulling the diagnostic codes... it's the most simple and easiest way to figure out what's going on: XenonZcar.com Z31 ECU Diagnostics
Also check that you've reinstalled the spark plug wires in the proper firing order. And disconnect the MAF plug to see if that makes a difference. Also, I'm hoping you already have the FSM if you've done a fuel injector replacement, but if not, download it right now... because it also contains amazing trouble shooting steps:
Z31 Factory Service Manuals
Old Feb 9, 2017 | 08:54 AM
86tcoupe's Avatar
There is/ was a TSB update
where nissan will replace the injectors and wiring on 84 to 86 Z31 for fuel leaks ,I got it on mine after a DSM consultation
​​​​​​​and a dealer may have the break out box tool to see live data
isabellbtr
Sep 20, 2017 04:06 PM
Kevdogg
Jun 23, 2014 09:53 AM
jgw2205
Apr 3, 2009 04:10 PM
Tuuurbo
Dec 16, 2003 06:41 PM
Teddyz
Oct 4, 2001 12:52 AM
