280zx bogs down on acceleration
Old Jun 12, 2014 | 06:48 PM
Kevdogg's Avatar
Have 83 280zx non turbo replaced wires rotor plugs etc. checked timing and is right idles great and runs good but when idling and driving when I push on accelerator rpms go down and kinda bogs then revs up once im going everythings fine just seems to lose power on intial acceleration.. any suggestions of things I should Check???
Old Jun 12, 2014 | 07:50 PM
borini63's Avatar
History on the Z??
Old Jun 13, 2014 | 08:30 AM
burble_boy's Avatar
Have you checked your vacuum hoses? That would be the first thing I would check since you already did the timing. Have you looked at the FSM to see what else could be causing that symptom?
Old Jun 13, 2014 | 03:16 PM
Kevdogg's Avatar
Originally Posted by borini63
History on the Z??
Car sat for couple years starts up everytime and seems when it warms up its not bad still hearing flap in afm smack every once in a while was thinking to cut out catalytic converter looks original but might be clogged????
Old Jun 23, 2014 | 09:03 AM
Kevdogg's Avatar
Thanks to all who replied with an answer cant what till I have another Question...
Old Jun 23, 2014 | 09:41 AM
PredatorZ's Avatar
Hard to diagnose
hard to figure out your issue from what you have posted. have you downloaded the fsm and went through the troubleshooting steps ? It will work you though diagnosing what it is. No way we can tell what is wrong, and asking if the cat is clogged isn't much help. Once you have done the steps, you will have a better understanding of what is going on. We can help you once you start narrowing down the problem. The EFI system is pretty strait forward, there are a lot of connections that can be corroded, after time the plastic in these cars becomes brittle, wires and connectors can break. You just need to do the steps, when stumped come for help. If you only post once every 2 weeks, very few people will see the old thread after a day of posts, so it's not that we are ignoring you, you have to be proactive to keep your post in the lime light per say. If you are serious, post daily with questions, the empty drum and the squeaky wheel make the most noise... so keep posting with more descriptions of what you are experiencing, a video with good sound if possible.
Old Jun 23, 2014 | 09:53 AM
PredatorZ's Avatar
Also
If a member posts a reply, asking if you have checked the vacuum hoses, and no response from you, well, we will wait for you to do this simple step and get back to us, so we are not wasting anyone's time. It could very well be a vacuum issue, or timing advance issue. Check all the ends of your lines, sometimes all you need to do is trim of 1/2 inch of hardened rubber to get to a more pliable supple section. Does the car run ruff if you remove the dip stick or oil fill cap ? If yes, that is a good sign you have a stable vacuum, or a very tiny leak. As many have said before, don't just start swapping parts, best to do the troubleshooting steps.
Incognitjo
Aug 19, 2014 11:47 AM
aojedam
Aug 1, 2010 05:58 PM
Sgonzo
Jul 2, 2010 09:10 AM
maalsa
Jan 21, 2009 07:26 PM
Tuuurbo
Dec 16, 2003 06:41 PM
