Fuel sending unit removal question
Old Feb 21, 2013 | 06:21 AM
wbnethery3's Avatar
Last night I tried to get the fuel sending unit out but ran into a snag. It appears there are 8 "bumps" around the perimeter of the sending unit (arrows pointing them below), but only 4 notches in the tank to align them with (that I can see). Is this just an optical illusion, or is there a trick I haven't found in the FSM or any other posts here? The one problem I had was getting hold of the top, but I missed the part in the FSM that showed using an "appropriate wire" to pull it with... maybe it was just a lack of effort on my part...
Thanks in advance...
Bryan
Old Feb 21, 2013 | 05:43 PM
wbnethery3's Avatar
Successfully removed it... just had to use an "appropriate wire" and a little extra tug... it was happy with where it had been for the last 27 years...
Old Feb 21, 2013 | 08:04 PM
rogerz's Avatar
Grumpy & Helpful
one of the few times when the greater force theory works without irreparable damage. I had to do the same.
Old Oct 16, 2014 | 05:46 AM
Sjackson6174's Avatar
I just bought an 84, that has sending unit issues, and I would like to know exactly how to get it out.
Old Oct 16, 2014 | 09:19 AM
rogerz's Avatar
Grumpy & Helpful
are you too lazy to download the fsm and read it. there is a pic at top of post. in back round cover on gas tank. two screws, eight nuts (maybe six) and you will see what is in the pic. there is a wire loop attached to the unit. use a pry bar thru that and a piece of 2x to lever the unit out of the tank. Don't smoke while doing this nor have open flames available.
Old Oct 16, 2014 | 09:16 PM
reddzx's Avatar
Let me google that for you
Old Nov 20, 2014 | 11:31 AM
cbernone's Avatar
Just yank old one out nissan sells new ones for $159
Old Nov 20, 2014 | 04:27 PM
zxguy1986's Avatar
By the way, when you replace the sending unit, check the fuel level it reports to the gauge before you close everything back up. My replacement sending unit reported about 4 gallons LESS than was in the tank. That makes Betty bitch earlier than she should. Better than 4 gallons MORE than in the tank, sure, but still a pain in the butt. SO check what the sender says and, if needed, adjust it however that is done on the unit you put in.
Old Nov 21, 2014 | 08:46 AM
PredatorZ's Avatar
Sending units
I have a few z31's I am parting, gas tanks still untouched, one is an 86t the other an 84 NA, if anyone needs a part just pm me
RETICON
Jun 8, 2013 11:29 PM
houlis1211
Feb 24, 2013 07:04 PM
rjc280z
Sep 29, 2009 01:13 PM
Carl's Z
Sep 12, 2005 04:53 PM
ratedZ
May 26, 2001 07:58 PM
