flywheel troubles
Old Mar 5, 2012 | 08:35 PM
Rootie524's Avatar
flywheel troubles
I am having major trouble trying to source out a new flywheel for my 88 non-turbo z31. I found an article that said flywheels for the 84-86 turbo are the same for the NA models. which can't be the case because the turbos and non turbos have different clutch sizes.
i also saw somewhere that you can put a turbo flywheel and clutch set on a non turbo z31. but im afraid the flywheel is larger and wont line up with the starter or may be too big for the bell housing.
they say all the flywheels are the same size but i looked at one at autozone and the turbo one appears to be larger. i cant find a non turbo flywheel anywhere. i have no idea what to do, ive never had so much trouble. any help would be greatly appreciated. thanks.
Old Mar 6, 2012 | 01:30 AM
PredatorZ's Avatar
Flywheels and clutchs
Heres a link to what you are asking about, seems you can use a turbo flywheel, just order a turbo clutch also.
https://www.zdriver.com/forum/showthread.php?p=303415
Old Mar 6, 2012 | 07:21 PM
reddzx's Avatar
Only 87-89 turbo flywheels are 250mm. all others, 84-89 NA and 84-86 Turbo's are 240mm. They are all interchangable with a matching clutch.
Old Mar 7, 2012 | 04:28 AM
AZ-ZBum's Avatar
Originally Posted by reddzx
Only 87-89 flywheels are 250mm. all others, 84-89 NA and 84-86 Turbo's are 240mm. They are all interchangeable with a matching clutch.
Please note that this is the clutch disc surface only. The overall diameter of the flywheels for all VG30 Z31s is the same.
This is completely the case. All NAs and the 84 to 86 turbos use the same flywheel. Look up the part numbers yourself if you don't believe it.
They're here:
http://z31.com/fiche/2/i02.gif
Old Mar 14, 2012 | 06:41 PM
Rootie524's Avatar
ok ill use the turbo flywheel with matching clutch. thank you!
askingxforxit
15
Sep 21, 2011 01:09 PM
ksampara
Jun 24, 2004 05:54 AM
futureZowner
Apr 12, 2004 11:05 AM
Rick280zxt2
Jun 24, 2003 06:37 PM
Beef
Oct 11, 2001 07:39 PM
