final drive ratio
Old Dec 16, 2014 | 12:21 PM
cbernone's Avatar
lsd carrier
Lsd carrier should swap right in R200. No mods needed just some labor. Old parts fit right in.
Old Dec 17, 2014 | 11:55 AM
cbernone's Avatar
final drive ratio
Does this depend on the lsd or ring and pinion gears? Lsd is 3.7. Ring and pinion is 3.9.. where do I stay at?
Old Dec 17, 2014 | 12:44 PM
Not sure what your question is... LSD = Limited Slip Differential. It's not the gear, it's the locking mechanism. If you are using a stock Z31T LSD, then it's 3.7:1, if you adapted a 3.9 gearset, then you have 3.9.
Old Dec 17, 2014 | 01:01 PM
ken99's Avatar
If you purchased a complete R200 carrier (with LSD differential case), then it already has it's own ring and pinion gear setup, which must be labeled as a 3.7:1.
FubarI33t
Oct 14, 2006 04:34 PM
DrSideways
Apr 10, 2003 12:54 PM
DrSideways
Apr 9, 2003 08:28 AM
DrSideways
Apr 9, 2003 08:23 AM
DrSideways
Apr 9, 2003 08:22 AM
