Convert Cedric with VG30E to turbo
Old Nov 5, 2007 | 12:10 AM
jeddahrace.com's Avatar
Lightbulb Convert Cedric with VG30E to turbo
i have cedric and it has vg30i and i converted it to EFI .. what i want to do now is converting this vg30e to a turbo .. just a got turbo and its stuff and blow off valve and i want to install it soon ..
the compresstion ratio is 9:1 (we all knows that) .. we also has fuel preiumum 95 octain .. how much boost i can gain on my STOCK engine (9:1) ??
i ran my car with 280Z (L28) ECU with that old harness and L28 AFM.. and its works fine with NA.. can i run the turbo by this ecu too.. we did it before ( we ran VG30ET (turbo engine) with L28 ECU and it'w work fine) but the 9:1 na when we install turbo .. is it dangrous to run it by L28 ECU..??
u may ask why u use L28 ECU AND AFM.. because it adjustable by a scraw driver in minutes..
again my question ..
how much boost i can gain on my STOCK engine (9:1) by 95 octain fuel ??
i will not install an intercooler
Old Nov 5, 2007 | 05:43 AM
260zturbo's Avatar
Stupid Hurricanes...
why no intercooler? depends how much you tune. i would start off stock and keep tunning till you can go up on the boost. but if your set on no intercooler install methanol. i would say u can safetly do 9lbs but again it comes down your tunning skills.
Old Nov 5, 2007 | 08:12 AM
entropy31's Avatar
The Cake Is A Lie!
on an NA engine with the stock pistons i would not go above 6-7psi.
Old Nov 5, 2007 | 08:24 AM
we know the old z31 version has boost 6.8 psi and cr 7.8:1 and the newer version of the z31 reduced to 4 or 5 psi with new cr 8.3:1 ..
my na is cr 9:1 and i can go with 7 psi?? without intercooler.. ??
i think i have to put only 4 psi .. what u think ..
waiting ur reply..
Old Nov 5, 2007 | 08:28 AM
another thing.. the STOCK VG30ET what the higher boost (psi) i can get without intercooler.. i heared i can get 15 psi without intercooler on VG30ET..(turbo pistons)
also what is the hp i can get from my NA if i ran 7 psi ??
what is the the highest hp i can get from VG30ET without intercooler??
Old Nov 5, 2007 | 08:35 AM
those are un-answerable questions ^^^ do it and find out. but if your going to turbo a 9:1 engine, which isnt much since its a strong block at least, run a good intercooler system and then that CR wont limit you by much at all.
Old Nov 5, 2007 | 09:45 AM
turboZ87.300's Avatar
I have ran a vg30e N/A with a turbo at 11psi with no problem using 87 gas and no intercooler. The lower end can hold over 300hp.
Old Nov 5, 2007 | 10:24 AM
yes this is the answer i were looking for.. thanks deeeeeaar, i will go into my setup as soon as possible..
another thing .. do u know the liter of 95 fuel just costs 0.173 $$ .. coz we in ritch country of petrol in middle east..
Old Nov 5, 2007 | 11:59 AM
If they paid you to fill up in the Middle East, I'd still be living right here in the USA.
Old Nov 5, 2007 | 10:06 PM
i got this answer from another website (vgpowered):
the most you'll be able to run on a daily basis is stock boost (6.8psi) your 95octane gas + retard the ignition timing about 1 degree or so....then take it easy...
Get some high octane race gas, like 100octane and you can safely run up to 14psi with no probs.
Hope this helps.
Old Nov 6, 2007 | 07:39 PM
I drove my vg30e with 11psi over a year 6-7 days a week with no probs... and that's on 87 pump gas... only 1 time a had to up 90...
Old Nov 6, 2007 | 08:28 PM
260zturbo's Avatar
i still dont understand why not to intercool. it will help u out in the long run.
Old Nov 6, 2007 | 09:27 PM
it will help you out in the short run to...
Old Nov 14, 2007 | 12:44 PM
Matt K's Avatar
Maybe plumbing issues, or most likely money issues...
Old Nov 14, 2007 | 06:38 PM
To do an inercooler in CA... not likely... got to fight smog... and if a cop pulls you over... they could take your car go having mods on your car... I have a friend or two that have thier car towed for eng. swaps even for putting on a KNN cone filter... soooo I'll put an inercooler on my 510 that needs no smog...
woodlandSerenad
Jul 5, 2015 08:00 PM
dustinsfairlady
Jun 30, 2015 07:57 AM
jtessmer
Feb 9, 2012 08:05 AM
scorpionp54
Jan 29, 2008 11:56 AM
robert
14
Oct 9, 2004 09:55 AM
