can somebody help me how to connect a oil pressure gauge
Old Aug 1, 2011 | 11:39 AM
dajude's Avatar
i just bought a 1988 nissan 300zx and the oil pressure gauge has been remove can somebody help me out how to re install it thanks
Old Aug 1, 2011 | 11:48 AM
Welcome to ZDriver!
Are you talking about the actual gauge in the dashboard, or the sensor on the engine? And do you have the original part to re-install?
Old Aug 1, 2011 | 02:15 PM
AZ-ZBum's Avatar
Put sensor in block in old sensor's location.
Mount new gauge in car.
Run wires.
Old Aug 1, 2011 | 09:23 PM
dajude's Avatar
sorry i was talking about the gauge in the dashboard...i dont know where to wire it or what to do.. thanks
Old Aug 1, 2011 | 11:25 PM
AZ-ZBum's Avatar
If you're talking about the stock gauge, just put it in place and connect the original wiring. What's the problem?
Old Aug 2, 2011 | 06:02 AM
dajude's Avatar
i dont see any wirings, thats the problem and i dont know which wiring
Old Aug 2, 2011 | 09:59 AM
rogerz's Avatar
Grumpy & Helpful
download the fsm from xenon. take the electric schematic in pdf format to kinko's and have it printed on 11x17 paper. Now read the schematic and you should be able to find the wiring you need. if you can't read the schematic don't mess with any thing that uses electricity in your car or find a friend who can.
Old Aug 2, 2011 | 10:56 AM
AZ-ZBum's Avatar
There should be a big connector right there where the original gauge was. If not, you're going to have to get a new dash harness.
Old Aug 23, 2011 | 03:44 AM
SkillZ's Avatar
Oil pressure & Oil temp. Should be a combo gauge
Old Aug 23, 2011 | 03:50 AM
SkillZ's Avatar
..look well. Highly unlikely someone removed it from the harness. Personally, Id swap for a mechanical gauge.
Old Aug 23, 2011 | 05:57 PM
AZ-ZBum's Avatar
Anyone who runs a mechanical oil pressure gauge into the cabin of their car deserves it when they get sprayed with scalding hot oil when the feed line breaks.
Only idiots use mechanical oil pressure gauges INSIDE THEIR CAR.
MurphyEF
Dec 31, 2012 11:03 AM
chukker
Oct 8, 2005 03:58 AM
Fast240Z
Sep 26, 2005 12:01 PM
TX_zx
Jul 12, 2004 12:15 PM
AllmyZs
Sep 17, 2003 11:29 AM
