Low oil pressue. Switch or pump?
Old Aug 18, 2011 | 12:00 AM
Flacster's Avatar
So I have inconsistent oil readings from my z. In the morning when I first start it up it idles a lil high(1400rpm) and has a reading of abt 50ish. Right above the 45 mark. When the car starts to get warm and the rpms back to 800, the pressure goes down to 30ish. When starting up warm, it will read 10 or nothing sometimes. When I'm cruising on the freeway it will sometimes read 50ish or 20ish other times. I don't believe I've ever seen my z go more than 60 on the digi dash unless on cold start up. What do u guys think?
Old Aug 18, 2011 | 08:20 AM
tonsoffun300zx's Avatar
West Coast!
thats about normal i believe or atleast thats what mine reads about.
Old Aug 18, 2011 | 08:26 AM
I think the factory gauges are worthless, inconsistent and inaccurate piles of ****. you are most likely running about 40psi at idle when cold and you are most likely cruising about 30-35psi. You really don't need more then 20-25psi of oil pressure at idle when warm though to properly lubricate.
Old Aug 18, 2011 | 02:23 PM
Flacster's Avatar
Think I need a new sending unit? Im mostly worried about the oil pump cuz I'm going to use it for ky vg33 build maybe.
Old Aug 23, 2011 | 09:44 PM
Flacster's Avatar
Is there anyway to check if the oil pump is working correctly?
Old Aug 24, 2011 | 07:41 AM
AZ-ZBum's Avatar
It's a very simple mechanical device. If it weren't working, your engine will lock up in less than a minute. It's the sending unit. They are notorious for going bad. Even worse if you get one from any auto parts store. Just spend the extra $5 or $10 and get it from the dealership.
Jason280ZX
Dec 26, 2013 11:37 AM
sameerb1
Mar 20, 2011 05:21 AM
ern
Oct 20, 2006 07:01 AM
91Zman
Oct 23, 2005 11:51 AM
ZenArcher
Aug 18, 2001 11:27 PM
