Brake upgrade
Brake upgrade
hey, by any chance does anyone know wher i can get 2-4 piston calipers for the front and 2piston in the back? Ive looked everywhere for a big brake kit *even ebay*. if anyone knows a source, post plz.
and if this doesnt exsist, then a place where i can buy the 2 piston OEM calipers for the front, ive been trying for those too.
Z32 calipers...
I even googled "Z31 brake upgrade" for ya:
http://www.mygen.com/users/dbruce/my...ke-Upgrade.htm
ruh... ruh... really son...
Did I stttttttttudddddeerrrrr????
Hey... more googlenet results from da google machine:
http://www.redz31.net/pages/brakes.html
http://www.z31.com/mods/brake.mods.shtml
http://giggles.z31.com/forum/viewtop...62309d055b1703
http://www.arizonazcar.com/z31front.html
Did I stttttttttudddddeerrrrr????Hey... more googlenet results from da google machine:
Z32 calipers...
I'm putting money on him not actually doing it.
so i finally got my 4 piston calipers from some guy in Chicago.. they came off a 92 N/A... I showed them to my Home boy and he said that i got the "Lame" calipers.. that there are 26mm *mine* and that there are 30MM *best ones*..
is there really a difference? or is it all just the same?
... I need a smilie of a head repeatedly hitting a brick wall ...
But this will do for now:
Did you click on ANY of those links I posted?
Did you do ANY other research before splurging on calipers?
Have you heard of the marvelous website search engine called GOOGLE?
You should be fine w/ the 26mm calipers, but you will need to use the appropriate rotors to match it:
PLEASE CLICK ON THIS: http://importnut.net/300zxbrakeswap.htm
(Are you sure they came from a 92 na?)
The following is a comparison of some different Z32 300ZX brake calipers.
The "26mm Aluminum" calipers were used ONLY on 1990 non-turbos. They used a 280mm x 26mm rotor.
The "30mm Aluminum" calipers were used on 1990 Twin-turbos and ALL 1991-1992.5 300ZX's (both turbo and non-turbo alike). They used a 280mm x 30mm rotor.
The "30mm Iron" calipers were used on ALL 1992.5-1996 300ZX's (both turbo and non-turbo alike). They also used the 280mm x 30mm rotor.
Of course, the easiest way to tell aluminum from iron is to use a magnet, but I hope this helps some people trying to figure out what they've got/are getting if buying with just a picture for info.
ehh, alright i guess il just buy the aluminum 30MM. il sell these 26mm..thanks.
and yes the description was a 92 N/A. wierd.....well its kool, I found the aluminum calipers used. thanks for the info dude, i know i should be googleing all this stuff and i did click on all the links, im just really busy to remember or notice some things. but thanks again man!
Don't buy the 90-96 rear calipers because they will not work without extensive modification.
You MUST buy a set of 87-89 turbo hubs and rotors to make the Z32 calipers work.
CodeWarrior
Sep 15, 2005 06:09 AM
