Brake upgrade
Old Mar 19, 2011 | 07:05 PM
HexaggramJDM's Avatar
Brake upgrade
hey, by any chance does anyone know wher i can get 2-4 piston calipers for the front and 2piston in the back? Ive looked everywhere for a big brake kit *even ebay*. if anyone knows a source, post plz.
and if this doesnt exsist, then a place where i can buy the 2 piston OEM calipers for the front, ive been trying for those too.
Old Mar 19, 2011 | 07:14 PM
Z32 calipers...
I even googled "Z31 brake upgrade" for ya:
http://www.mygen.com/users/dbruce/my...ke-Upgrade.htm
Old Mar 21, 2011 | 10:51 AM
so Z32 calipers are a direct fit? to a Z31?? thats what its saying here obviously but really?? i can get the Z32 caliper and fit it in?
Old Mar 21, 2011 | 11:00 AM
ruh... ruh... really son... Did I stttttttttudddddeerrrrr????
Hey... more googlenet results from da google machine:
http://www.redz31.net/pages/brakes.html
http://www.z31.com/mods/brake.mods.shtml
http://giggles.z31.com/forum/viewtop...62309d055b1703
http://www.arizonazcar.com/z31front.html
Old Mar 21, 2011 | 11:27 PM
AZ-ZBum's Avatar
Z32 calipers...
Do you ever get the feeling you're talking to a brick wall? You provided a link that contained every possible piece of information he'd need and he still has to ask a question about it?
I'm putting money on him not actually doing it.
Old Mar 29, 2011 | 08:45 PM
so i finally got my 4 piston calipers from some guy in Chicago.. they came off a 92 N/A... I showed them to my Home boy and he said that i got the "Lame" calipers.. that there are 26mm *mine* and that there are 30MM *best ones*..
is there really a difference? or is it all just the same?
Old Mar 29, 2011 | 09:56 PM
... I need a smilie of a head repeatedly hitting a brick wall ...
But this will do for now:
Did you click on ANY of those links I posted?
Did you do ANY other research before splurging on calipers?
Have you heard of the marvelous website search engine called GOOGLE?
You should be fine w/ the 26mm calipers, but you will need to use the appropriate rotors to match it:
PLEASE CLICK ON THIS: http://importnut.net/300zxbrakeswap.htm
(Are you sure they came from a 92 na?)
The following is a comparison of some different Z32 300ZX brake calipers.
The "26mm Aluminum" calipers were used ONLY on 1990 non-turbos. They used a 280mm x 26mm rotor.
The "30mm Aluminum" calipers were used on 1990 Twin-turbos and ALL 1991-1992.5 300ZX's (both turbo and non-turbo alike). They used a 280mm x 30mm rotor.
The "30mm Iron" calipers were used on ALL 1992.5-1996 300ZX's (both turbo and non-turbo alike). They also used the 280mm x 30mm rotor.
Of course, the easiest way to tell aluminum from iron is to use a magnet, but I hope this helps some people trying to figure out what they've got/are getting if buying with just a picture for info.
Old Mar 29, 2011 | 10:58 PM
ehh, alright i guess il just buy the aluminum 30MM. il sell these 26mm..thanks.
and yes the description was a 92 N/A. wierd.....well its kool, I found the aluminum calipers used. thanks for the info dude, i know i should be googleing all this stuff and i did click on all the links, im just really busy to remember or notice some things. but thanks again man!
Old Mar 30, 2011 | 06:24 AM
reddzx's Avatar
Don't buy the 90-96 rear calipers because they will not work without extensive modification.
You MUST buy a set of 87-89 turbo hubs and rotors to make the Z32 calipers work.
Old Mar 30, 2011 | 02:29 PM
Kool, thanks for that info too! il just upgrade the front for now, Thanks =)
Old Mar 30, 2011 | 02:37 PM
tonsoffun300zx's Avatar
West Coast!
post pix i may want to take the front and back calipers off your hands if you're willing?
Old Mar 30, 2011 | 08:10 PM
you want my stock 88" N/A front and rear calipers? Sure, let me just finish doing the swap...il send you a message =)
Old Mar 31, 2011 | 12:05 AM
West Coast!
i have an 88 turbo don't need stock n/a thought you were upgrading ti the 30mm's
Old Mar 31, 2011 | 07:02 PM
Ooh you mean the 26mm?? I sold them already...srry =(
jtz31ae
May 30, 2008 03:54 PM
apollo
Mar 19, 2007 11:49 PM
CodeWarrior
Sep 15, 2005 06:09 AM
sk8ur_9
Dec 20, 2004 08:03 AM
1tuffz
May 8, 2003 12:42 PM
