300zx/280zx buying advice
Old Mar 2, 2006 | 07:26 AM
pmr2000's Avatar
Going to check out an 88 NA, 86 Turbo and a 83 280zx this weekend, all high mileage cars.
What's the general opinion about z31 turbo's, should I stay away from them if I don't want to sink a lot of money into the car? Are 280zx's just too old, hard to find parts for? Any real problem areas specific to zx's, I know to look for rust underneath.
Currently I have a RX-7 but have had a couple of 240Z's years ago.
Thanks.
Old Mar 2, 2006 | 07:30 AM
Sp4rt4n's Avatar
Depending on the condition of each car, Id go with the '86 turbo. Youll be happiest with that if your looking for performance. (If the turbos spool)
Old Mar 2, 2006 | 08:16 AM
For any car.... be specific when looking at the car. Look for rust all over. Look for possible damage (accident) repairs. Oil leaks from the engine, trans, diff. yada yada yada. Just look over everything in detail.
Old Mar 2, 2006 | 08:24 AM
pmr2000's Avatar
O.k. so we're saying a turbo can last if maintained?
I know a lot of guys in our RX-7 club have a lot of problems with their turbos.
Should I forget about 280zx's, are they just too old hard to get parts for?
Old Mar 2, 2006 | 08:59 AM
When you take the turbo for a test drive, listen for the spool sound. if it whines or whistles more that usual, then you should be concerned. Also check it's oil. Turbocharged engines need to have clean oil.... if the oil is really dirty, the turbo bearing (entire engine for that matter) is going to have more wear.
280zx turbo's are great cars. Parts are just as available for them.
oh.... and 99% of the time, when people have probs w/ turbos, it's because someone is an idiot & doesn't know how to take care of a turbo.... i.e. let it cool down before turning it off. A lot of throttle happy people don't take the time to care for their car.
Old Mar 2, 2006 | 12:38 PM
RodMoyes's Avatar
Doesn't post much...
The search button is your friend... Welcome to ZDriver.
Rod.
Old Mar 2, 2006 | 09:27 PM
jfairladyz's Avatar
First off the 280zx is NOT too old . Take everyone else advice and just really look the cars over.
Basically it comes down to what you want to get out of the car. Taking into the theoretical consideration that all 3 are mechanically in the same state and rust hasn't significantly attacked any single one: Which would you rather own? the Z31 or the S130? Which catches your eye more? For the Z31's: If both are in good shape take the turbo car. THere is absolutely no reason to NOT take the turbo car unless it was neglected. Replacing the turbo can cost as much as an entire engine in some cases. A turbo engine isn't any more unreliable or troublesome then a non turbo car. Just make sure you put forth the extra effort to keep it maintained (and make sure the previous owner did the same).
Old Mar 3, 2006 | 12:19 PM
AZ-ZBum's Avatar
http://z31.com/lookfor.shtml
Old Mar 6, 2006 | 05:31 AM
pmr2000's Avatar
bought an '84 300zx
Wound up buying the 84 300zx, 76,000 original miles but has some rust issues. Over $4,000 or receipts and 20 years of documentation so the mileage seems legit, do not do a carfax. Recent work was timing belt/water pump/front pulley/tune up/front end/tires/brakes/muffler all done by Nissan dealer.
Any suggestions on the following problems:
1-Clutch is almost gone, any suggestions on where to get replacement parts/brand?
2-right front fender hit (bumper/headlight/door/hood fine) where can I get a replacement, how hard is it to replace?
3-rust on lower rear quarters, unibody rails are good but front right floor is rusting and more importantly back right plate, not sure if this is control arm or what? There is a area with a metal plate with bolt and sway or control arms attached?
Any rust tips?
I bought this car dirt cheap as a project, the owner wanted someone to save it not part it out.
Thanks
Old Mar 6, 2006 | 10:12 AM
jfairladyz's Avatar
First off congratulations on your purchase.
1. There are a number of places on the web, including ebay that sell good clutches for cheap. If the car is all stock then a factory spec clutch will work just fine.
2. The first place I would check for a fender is the junk yard. Z31 seem to be fairly abundant in junkyards. Of all the Z's they are the one I see most of. If that fails ask around the forums and check ebay from time to time. And finally you could always buy a new one from places like www.zcarparts.com and Nissan.
3.If the rust isn't bad you can try to wire brushing it off. If it's penetrated the metal then you've got two choices. First, if you're good with a welder and metal working then you can do the work yourself. Otherwise you can take it to a body shop and have them do it. I guess a third option would be to ignore it
Old Mar 6, 2006 | 10:31 PM
duowing's Avatar
NisTuner
Wehn having a body shop do that kind of work. How much can that run. That's something I've always wondered.
Old Mar 7, 2006 | 02:37 AM
AZ-ZBum's Avatar
Depends on the body shop and the quality of work. There is no FIXED amount.
Old Mar 7, 2006 | 07:53 AM
pmr2000's Avatar
Thanks for the replies, now I have a museum of 80's Japanese sports cars in the garage-'88 RX-7 and '84 300ZX.
As far as the welding, I once had a '71 240Z front right rail and floor welded back around 1983, it cost me $400 then! But it was pretty bad, the rail was pulling away from the body when you hit the brakes.
marco.S
May 28, 2013 09:25 PM
skeptikkkk
Apr 9, 2013 03:00 PM
tylercaviness
Apr 4, 2011 03:09 PM
pmr2000
Mar 2, 2006 12:18 PM
turrbo
Jan 27, 2002 01:58 PM
