1985 N/A to Turbo Swap, No Electrics/Crank
Old Mar 1, 2013 | 09:39 PM
iammclovin804's Avatar
Hello everyone! I just bought this car two days ago as a project. The PO drove it for a while N/A and blew the motor. Picked up a donor turbo car and swapped the drivetrain. Now, he said since he swapped the motor it wouldn't turn over. From what I can see all electrical connections appear to be connected and I just bought a good battery today. The battery is pushing 12.56V to the cable but when I get in a turn the key to acc or run, nothing happens. No switches or lights work, the radio doesn't turn on, and of course the car doesn't turn over. It had a viper alarm system installed programmed to the original ECU. I figured that was the issue but I removed the entire alarm and still nothing. I'm out of ideas right now and I need some community brainstorming. Any help would be much appreciated.
Old Mar 1, 2013 | 10:12 PM
rogerz's Avatar
Grumpy & Helpful
fusible link maybe?
Old Mar 2, 2013 | 08:14 AM
How exactly would I test the fusible link?
Old Mar 2, 2013 | 01:29 PM
rogerz's Avatar
Grumpy & Helpful
download the fsm from xenon for a start. Read it. pull the cover and see if a link is fried. better is test with a vom
Old Mar 2, 2013 | 02:55 PM
I got all of the electrics to work. One of the wires going to the alternator was grounded when it was supposed to be powered. But I still can't get it to crank. I hear a clicking from the driver kick panel.
Old Mar 2, 2013 | 06:32 PM
Found an ignition wire that was unplugged by the ecu. It went to the theft relay in the engine bay. So now she turns over but won't fire. I pulled a spark plug and I smelled fuel but there wasn't any visible. Also connected the plug to the boot and didn't see any spark. Ideas?
Old Mar 3, 2013 | 03:12 PM
Fuel pump relay was bad. Replaced that so that's good on the fuel side. But now I think my PTU is bad. I got 12v from the harness but I don't know how to test the actual unit. Help por favor?
Old Mar 11, 2013 | 09:08 PM
I replaced the PTU and still not starting. All of my fusible links are good. I really need some help here guys/gals.
Old May 14, 2013 | 01:46 PM
FlyAssMelonBall's Avatar
I would just check the fuseable links again, this sounds like the exact problem i had and it was the fuseable link.
Old_timer
Aug 26, 2015 04:50 AM
thesantaman
Nov 29, 2012 08:13 AM
Z-bras
Jun 20, 2012 10:58 PM
smokey
Jan 12, 2007 07:47 PM
motoxracing909
Oct 21, 2005 11:51 AM
