YiPPY! and WTF is that noise?
Old Apr 22, 2013 | 02:05 PM
pnoyslimm's Avatar
I traded 2 sets of S30 headlight covers(i paid $35 for both) for this!
Now for WTF is that noise?
i tried figuring it out on my own. i read thru numerous threads. used the searched button till my fingers hurt and i still cant find a close/good answer.
when i put load on the motor i can hear this high pitch sound. the sound fades away as the motor idles down. but always is heard(when its quiet enough) when load is put to the motor. the sound sounds like someone hitting a tuning fork.
ideas?
Old Apr 22, 2013 | 02:53 PM
icice9's Avatar
Super Siver & Black Stud
ideas?
try putting some lube or wd40 on your belt tensioner pulley. might just be a dried out bearing.
Old Apr 22, 2013 | 03:17 PM
pnoyslimm's Avatar
I have lubed any rotating part that i figure would make the sound.
To me, it sounds internal. i cant seem to pinpoint the exact location. every time
i find where i think its coming from it sounds louder somewhere else.
Old Apr 22, 2013 | 03:27 PM
Skully's Avatar
Maybe you have a turbo :P
Maybe try recording it?
Score on the dam tho, always liked those.
Old Apr 22, 2013 | 05:31 PM
zedsdeadbaby's Avatar
Electrical noise?
Old Apr 22, 2013 | 11:30 PM
mrprofile's Avatar
yea, the diodes on an alternator can make high pitch noises when they are going out.
Old Apr 23, 2013 | 02:30 AM
borini63's Avatar
Smoken deal...good for you.
Do you hear the sound while you are sitting inside the car or poping the hood and earing away???
If you are inside and have an auto A/C some time the little climate control sensor fan make that noise.
looking at your ZX for me it looks like a 82 -83 year GLL model N/A and they come with auto A/C!!
Old Apr 23, 2013 | 03:20 AM
Gonzo's Avatar
Noise
Sounds like it could also be a vacuum issue such as a restricted air regulator or even a collapsed hose. Have you tried pulling the belts to see if it's still there? Could even be a PS hose or the pump itself. Are you running AC? Seriously doubt it's internal engine.
Old Apr 23, 2013 | 08:36 AM
take the belts off of the engine completely. that will eliminate all of the front rotating parts. if it goes away then check the pulleys for worn bearings. if not id be looking else where, like vacuum leaks or a bad stereo ground.
Old Apr 23, 2013 | 04:58 PM
pnoyslimm's Avatar
recording, failed. its not loud enough to capture unless i do some digital sound tuning, which im clueless to.....turbo,lol. i wish. my 300zx is though.
Originally Posted by zedsdeadbaby
Electrical noise?
it doesnt sound electrical.
correct on the model! but i have done an a/c delete. i do know that noise you speak of though, but its not what im looking for....i hope.
vacuum? i doubt.
i guess ill go this route when the sun shines.
thanx everyone for inputs!!! i'll keep looking!
turbojohnny
30
Jun 18, 2009 10:36 PM
Fast240Z
Nov 8, 2006 03:28 PM
Kraker_Jax
Feb 28, 2005 01:42 PM
79bigbore280zx
Oct 27, 2003 10:36 AM
SwiggA88zxt
Apr 23, 2002 03:15 PM
