Yes!!! Finally!!
Old May 8, 2006 | 11:48 PM
chinesekid's Avatar
Yes!!! Finally!!
over heating has stop!!! (i think) i let it idle for like 20 mins and i rev it to 3g for like 2 mins at a time.. and its not over heating anymore!!! yeS!!!! maybe driving is a differnt story but as of rite now im happy!!!
water pump i just installed...
and then new radatior i got from MSA
Old May 8, 2006 | 11:52 PM
chinesekid's Avatar
with the new radatior.. i couldnt put the shrout back on... is that bad? or do really need it?
Old May 9, 2006 | 06:18 AM
VenomousZX's Avatar
I'd say find a way to put it back on, when my Rad finally died I left the fan shroud off & the car seemed to run a little hoter than I'd like put it back on but be careful of the upper hose, you may have to remove it to re-instal the fan shroud
Old May 9, 2006 | 07:36 AM
It's easiest to put the shroud back on BEFORE hooking up the radiator hoses. You can still do it, but it's gunna take some skill. Or just pull the hoses back off & re-install. You should put it back in, as it helps cool.
BTW... That engine needs to be cleaned!
Old May 9, 2006 | 11:10 AM
chinesekid's Avatar
yea... engin has to be clean really bad... haha, alrite.. i'll try to put back the shrout.. i just didnt know if it was bad if i didnt put it...
Old May 9, 2006 | 11:21 AM
silvrhand's Avatar
Snazzy Title
YES! Put your shroud back on it affects the fan's ability to flow air through the radiator which is important when in traffic or slow moving. Also the radiator looks like it's already got rust on it??
Old May 9, 2006 | 11:24 AM
Looks to be a remanufactured rad w/ painted fins.... I believe the fins are copper / tin ???
Old May 9, 2006 | 06:28 PM
jfairladyz's Avatar
without the shroud the fan wont pull air through the radiator. It will pull it from around the fan blades instead as there is less resistance that way. The shroud is designed so that the air moved by the fan HAS to come through the radiator. It wont make much difference on the highway (if at all), but after you've been driving and you come to a stop and try to idle for any length of time your temps will start to rise as the coolant continues to heat but the heat isn't being dissipated.
Old May 9, 2006 | 10:41 PM
chinesekid's Avatar
oh.. alrite cool.. imma put it back on
but yea.. the radatior is copper or tin...
Old May 10, 2006 | 03:31 AM
I disagree with the shroud not being useful on the highway. When I didn't have my shroud on my '81. He would be fine, until I jumped on the freeway. And then all of a sudden within a few minutes, my temp gauge would quickly start sweeping over. It was annoying, but as soon as I found a shroud, and put it on. My Z didn't overheat as much. Of course I also had to get a brass thermostat, and that helped out a lot. Not trying to step on anybody, but the city driving didn't bother my Z at all without a shroud. But like I said, as soon as I jumped on the freeway within a few minutes, well you get the picture.
Old May 10, 2006 | 09:01 AM
jfairladyz's Avatar
thats strange wildman cause the ONLY point of the shroud is to help the fan direct air through the radiator. Thats it. The only time the fan is used is while at a stop or low speeds. On the highway your car doesn't rely on the fan for cooling, so in essense the shroud does nothing for cooling on the highway. So it's strange that it made a difference in your case.
Old May 10, 2006 | 09:37 AM
Darrel's Avatar
Registered Zee Racer
Those are long studs for the fan pulley, is that normal? I don't recall my zxt having them that long.
Old May 10, 2006 | 09:40 AM
jfairladyz's Avatar
those do look really long.
Old May 10, 2006 | 11:15 AM
chinesekid's Avatar
yea.. those were the wrong one.. the pump came with 4 long one's and 4 short ones.... and once i got it on and try to put the fan assemably on.. it couldnt go in.. so i changed it to the short one
Old May 10, 2006 | 07:18 PM
n00blar's Avatar
Heh, I was gonna say the same. I did exactly what you did the first week of owning my ZX...ahh the memories.
Nforce1
Jun 24, 2005 12:19 PM
ensmuns
May 3, 2005 05:38 PM
My Fairlady Z
Sep 27, 2004 01:14 PM
TheZerminator93
Aug 31, 2004 02:40 AM
ZenArcher
May 17, 2004 10:00 PM
