What's making this noise?
Old May 12, 2021 | 07:36 AM
B's ZEE's Avatar
My 83 zx 2+2 manual makes a strange whining-type noise coming from the rear at 45-47 mph only. The car only as 45K on it. Any ideas what could be doing it. Wouldn't be such a pain, but a lot of the cruising I do is in that range on back roads. Thanks.
Old May 13, 2021 | 07:08 AM
pbprutzman's Avatar
Rear diff
Old May 26, 2021 | 07:01 AM
B's ZEE's Avatar
what's making this noise?
Would a rear differential only make noise at one speed range..45-47mph? Car has 45K on it.
Old Jun 2, 2021 | 11:33 AM
There are only so many things... what have you checked? Wheel bearings? Axle u-joints & boots? Diff mount / bushing? Driveshaft? Tires? Check them........
Old Jul 19, 2021 | 06:25 PM
TriangleLaughin's Avatar
Could be a number of things...
- Rattling Catalytic converter - When these go bad or get loose or whatever it is, they will have a resonant buzzing sound that only occurs at very specific rpm/speeds
- Rearend - gear noise/humming. Most likely IMO. Change your gear fluid and see if that helps. You might be a bit low after all these years, or the goo is spent.
- Wheel bearing - maybe but I'd try changing the gear oil before anything else.
280zdude
May 15, 2009 03:43 PM
3riCJbOi
Nov 10, 2008 03:40 PM
kevtt
Mar 20, 2007 07:51 PM
apollo
Jan 26, 2005 03:35 PM
futureZowner
Sep 17, 2003 08:58 AM
