trying to get a feel of what noise is normal and what's not
I am new to the 280z world so forgive my ignorance. But I noticed this morning that there is a slight hum or whine in the rear of the car. I wasn't sure if this was normal due to the low gears or if there was a rear end problem.
It is automatic and I noticed the noise during all phases of driving. Is this normal?
You are right, it is a ZX. As far as the noise goes, the thing is i have owned but for a few weeks and this is only the second time I have driven it, so i don't know if it has been there all along or not.
a hum CAN signify the rear end is wearing away. if its only a little. i wouldnt worry about it, maybe check and change the diff fluid (if you can they really retarded up the fill plug on these cars) and see what happens. i suppose it could also be from a wheel bearing though so i would try to make sure its coming from the diff and not a wheel first. if it is infact the diff. not much you can do other than what i said and listen for any other odd noises it might be making or if it gets louder.
if it isnt a hum and is a vibration then it could be something else like someone above me said, but usually it will be accompanied by a clunking when starting off in first or going from reverse to first or vise versus
i didnt mention that because if there was clunking i would have assumed he would have mentioned it. and he just there verified that thought. probably a bearing, but if you can change the diff fluid and hope for the best. also like i said, try to make sure it isn't a wheel bearing thats making the noise.
hey guys. I been experiencing the same kind of noise at the rear end. Its like a vibration when accelerating from every gear. It suddenly wasnt making that noise today when I was driving home and it felt so much better. It actually felt like I had more power, but that could be just because I could hear the engine better without the vibration making me feel like i got some extra power.
Really i got no experience, so any help appreciated.
ZCARDiego
25
Mar 18, 2004 05:20 PM
