Trouble With Pertronix Coil
Hello everyone!
The car is a 1979 280ZX, everything's stock except an aftermarket exhaust.
I recently acquired an Pertronix Flame-Thrower 3.0ohms ignition coil, and when I install it within my car, it starts for a second, and then quickly dies. It's getting a second of spark because the car does run, so I know the coil is working, and that it's being properly ignited, but it cuts out after the first few RPMs. I have removed the coil and put in the stock and it started and ran fine.
Do I have to add/change some wiring? Does the 3.0ohm mean I have to use a resistor of some sort? I am very lost and confused!
And yes, the polarities are where they are supposed to be!
Thank you!
Thank you!
Ah...
Hopefully you got it for a good price. Coils can actually burn out if the internal oil isn't covering the actual coils (i.e. coil installed improperly), or if it's wired incorrectly. Usually you can find new coils on ebay for the same price as used ones (MSD Blaster II is a good one).
Ah...
traethetruth
Jan 5, 2011 05:31 PM
rar7775
Jan 15, 2010 06:21 PM
escapedan
Jun 21, 2009 07:50 PM
