Tire Question
Old Mar 22, 2013 | 01:24 PM
pnoyslimm's Avatar
Tire Question
when i got the car it had some brand new rubber on it. but the size puzzled me.
185/65/14 on 6 spokes?
why so small?
will this effect drivability? should i replace them with recommended tire size,
205/70/14?
Old Mar 22, 2013 | 01:44 PM
Where did you get 205/70/14 as the stock size?
I believe 195/70R14 is stock. 205/70 will be wider and taller (use this: Tire size calculator). They will still fit though.
Old Mar 22, 2013 | 01:58 PM
pnoyslimm's Avatar
oops, yea i meant 195/70.
i have done a tire size calculator. if i remember right it was -5% difference.
but what is the reason in going smaller?
edit: t-bar option size is 205/70, says, FSM.
Old Mar 22, 2013 | 05:38 PM
evandubya's Avatar
Primer Grey FTW!
faster acceleration.
Old Mar 26, 2013 | 08:43 AM
stock size on most models was the 195/70. 205/70 will fit just fine, if you want you can go 225/60 all the way around, it fits and gives you better traction and handling. 235/60 will fit on the back which is what i did to combat wheel spin but then you can rotate tires and increase the life of the tires.
Old Mar 29, 2013 | 10:36 AM
pnoyslimm's Avatar
225/65 sounds really appealing. after driving my first 300 miles in the 280 i really dont like the feel of narrow tires. feels loose around the corners...or maybe its because i havent put on my tokicos yet.
Old Mar 29, 2013 | 12:01 PM
That loose feeling is usually worn suspension, not the tires... unless you are losing grip. Just an FYI, taller tres means more sidewall, which means more sidewall flex.
New / stiffer suspension and bushings helps a lot with body roll and control.
Old Mar 29, 2013 | 03:59 PM
best upgrade ever is new suspension bits. drives like it did new. and you put 225/65, thats too tall go 225/60 it almost matches stock diameter.
Old Mar 29, 2013 | 06:27 PM
pnoyslimm's Avatar
i still need to cough up 160 dollars for new suspension bits. (All Moog parts.)Lower ball joints, sway bar links, strut bellow and bump stops and outer tie rods. i know i should change all my bushings but money is tight and im just replacing whats really needed for now.
225/60 is what i meant.
im having a hard time finding tires in 225/60/14.
Old Mar 29, 2013 | 06:47 PM
If you don't have $160 for suspension, how do you have $400+ for tires? Especially $400+ to replace "already brand new rubber" as you said.
Click: Google Search - 225/60R14
Make sure you are using "R" not "/" for the tire size...
Old Mar 29, 2013 | 07:39 PM
pnoyslimm's Avatar
just planning for the future. research before buying, right?
joeyjr25
Mar 6, 2015 06:35 PM
pvtcook
Dec 12, 2014 09:39 PM
orange7r
Apr 28, 2013 01:50 PM
thxone
13
May 12, 2006 12:18 AM
BlitZaceZ32
Mar 18, 2003 09:29 AM
