Thermostat question
Old May 4, 2015 | 08:41 PM
Tr0cken's Avatar
Thermostat question
Hi, this is my first post and I need some help.
I bought a cheap not running partially disassembled '79 280zx 2+2, and I'm trying to assemble it.
Cleaning the thermostat housing, I've found this:
As I've researched, the components are: Thermotime, Water temperature sender and Coolant temperature sensor. You can see in the picture that there is a broken (and missing) part, can you tell me if this is the missing part?
Water temperature sensing switch
Thank you!
Old May 4, 2015 | 09:53 PM
masterhufflpuff's Avatar
It looks like you have it correct as far as I can tell. But I would like a second opinion before taking my word.
Pick up a free copy of your FSM at http://xenons130.com/
This is the key to unlocking every question you may have in your car.
Attached Thumbnails Thermostat question-79-fsm-cooling.jpg   Thermostat question-thermometer-housing.jpg
Old May 5, 2015 | 05:19 AM
Tr0cken's Avatar
Thank you master, I do have the FSM but I was unsure about the part.
Now the challenge will be to remove the broken piece!
Old May 5, 2015 | 07:36 AM
Welcome to ZDriver!
Weld a bolt on the end and then your can back it out. Since the thermostat housing is aluminum, you can zap the heck out of it, the weld won't stick to the aluminum, but will heat it enough to loosen it.
Old May 5, 2015 | 09:01 PM
Tr0cken's Avatar
Welcome to ZDriver!
Thank you for the tip! I will try that.
Old May 6, 2015 | 10:05 AM
Zuphoria's Avatar
YA that looks right. different year cars sometimes moved sensors around on the housing, or the housing has block off caps if the car didn't have the option. The water temp sensing switch is used to operate the injector cooling fan i believe.
Old May 6, 2015 | 01:03 PM
Tr0cken's Avatar
Is the injector cooling fan the V-like thing that goes above the valve cover? Because I don't have it...
Old May 6, 2015 | 11:45 PM
Injector cooling fan should look like this
Old May 7, 2015 | 12:01 AM
borini63's Avatar
I have one for sale if you are looking to buy,also I have the thermo housing pulled from 80 280ZX too!!!!
Old May 7, 2015 | 12:30 PM
Tr0cken's Avatar
Please PM me with the info. Thank you.
Old May 7, 2015 | 12:41 PM
Tr0cken's Avatar
Does anybody know what is this? Can't seem to find it in the FSM.
Old May 7, 2015 | 01:41 PM
Skully's Avatar
Just a member of another forum that made this up, not sure how accurate, but seams reasonable, as throttle body had a heater in it as well.
Old May 7, 2015 | 01:46 PM
Tr0cken's Avatar
Thank you very much Skully! This is exactly what I needed.
oneadvent
Dec 23, 2010 12:52 AM
260zturbo
Aug 2, 2007 01:28 PM
SHADY280
May 1, 2007 03:58 PM
Mjollnir
Aug 21, 2002 05:09 PM
n8tros
May 10, 2001 04:40 PM
