thermostat
Old Dec 20, 2010 | 01:54 PM
oneadvent's Avatar
thermostat
How do i replace this? Can I get a link to walkthrough? couldn't find it in the FSM.
Old Dec 20, 2010 | 02:12 PM
On a 280zx? Really easy man. Look on top of the engine. You will see a radiator hose, with a piece going flat to the thermostat housing. Next to the valve cover, driver side. There is 3 12mm bolts. Use an extension, and a ratchet, to make it easier. Then, gently pull the piece off the housing. And the thermostat will be there. Depending on how long it has been in there, it might fight you a little but be careful. Use a flat head screwdriver, to gently pry it off. And it should. You will have coolant coming out the top of the housing. So if you want to drain the coolant. You wouldn't have to worry about it. I just do it real quick, and while doing so, and put a rag to hold the coolant in there.
You also might have to clean the surface. You want it nice and smooth, so you can put the new thermostat, and gasket on. Hope this helps, I really am terrible at explaining some things. Hope I didn't confuse you. Good luck man.
Old Dec 20, 2010 | 09:25 PM
evandubya's Avatar
Primer Grey FTW!
I understood what you said, I think I'll go replace mine right now!!!
Old Dec 21, 2010 | 12:01 AM
pete8717's Avatar
You don't have to drain out a lot. I put a small bucket under the drain **** and let out about a gallon and had no problems. Changed my thermostat today and it all went smooth
Old Dec 22, 2010 | 02:06 PM
GTH's Avatar
GTH
Seeing as you're in Florida you can prolly get away with leaving it out if you believe its causing issues.
Old Dec 22, 2010 | 09:21 PM
oneadvent's Avatar
Excellent, worked perfectly. I have hear of the leave it out idea too, but it was only a few bucks for the part, and it fixed my overheating problem.
Thanks a bunch!
Old Dec 23, 2010 | 12:52 AM
GTH's Avatar
GTH
Awesome, sounds like it was stuck closed. lucky it was only that, my over heating problem was much much more invasive :[
Tr0cken
May 7, 2015 01:46 PM
260zturbo
Aug 2, 2007 01:28 PM
SHADY280
May 1, 2007 03:58 PM
Mjollnir
Aug 21, 2002 05:09 PM
n8tros
May 10, 2001 04:40 PM
