Steering vibration
Old May 19, 2011 | 02:32 PM
mrprofile's Avatar
Steering vibration
I have a 79 2+2 with power recirculating ball steering with 80,000 miles and a recent alignment and suspension rebuild
So my problem is that my steering is vibrating kind of like if you took a piece of rubber and pulled it across a table and it vibrates as it tries to grip the table. The steering vibrates when it has some resistance put against it, like sitting still and turning the wheel to the far left will cause it to vibrate. I have already looked to see if it's low on power steering fluid, and It's not, so im thinking maybe the steering box need's greasing, but I cant find any grease points, anybody know if you can even grease the steering boxes? or whats causing my problem?
Old May 19, 2011 | 03:10 PM
BlueKitsune's Avatar
Intrawebz Wizard
You don't grease the steering box if its power steering lol
Check your front rotors. If their warped it will do that.
Old May 19, 2011 | 04:20 PM
noboosts130's Avatar
Lurker
You probably have a bad idler arm. Check for slack by pushing and pulling on the centerlink.
Old May 19, 2011 | 07:04 PM
mrprofile's Avatar
alright, thanks i will, its funny because I just had the rotors replaced a week ago, and I think i replaced the idler arm a month ago lol
Old May 19, 2011 | 07:08 PM
The steering wheel would only vibrate while braking if the rotors were warped.
If it vibrates all the time, get your wheels balanced yo....
Old May 19, 2011 | 07:09 PM
mrprofile's Avatar
I was just reviewing what I wrote and I would like to reword a couple things, It's not really a vibration, as it is a kind of rubbing feeling on the steering wheel, only when you move it and the sound can be easily made, by sitting still without moving and turning the wheel to its extremes
Dr_Nic_T61
13
Oct 4, 2016 12:05 AM
Evan Faris
May 3, 2013 04:22 AM
Purple_EnvyZ31
Mar 1, 2013 10:45 AM
datdude407
Jan 20, 2011 09:59 AM
graverhead
Dec 14, 2005 12:39 AM
