Speedometer calibration
Old Oct 30, 2008 | 11:33 PM
pete8717's Avatar
Hey guys. Does anyone know anything about calibrating the speedometer on the 81 non turbo ZX's? Mine is about 5-6 mph's fast and I have no idea how to fix it. Some help would be appreciated. Thanks guys. L8rZ
Pete
Old Oct 31, 2008 | 07:46 AM
You match the speedo cog w/ the diff ratio. Do you know which color speedo cog you have? Do you know what diff ratio you have?
Old Nov 1, 2008 | 08:10 AM
pete8717's Avatar
I don't know the color of the cog but i'm pretty sure i have the 3:90 gear ratio.
Old Nov 1, 2008 | 10:30 AM
Okay, is it the orig tranny, rear end, and speedo? Are you using the stock tire size?
Old Nov 1, 2008 | 10:42 AM
pete8717's Avatar
Original tranny, rear end and speedo. I think i'm using smaller tires though. P195/60R14
Old Nov 1, 2008 | 02:27 PM
Smaller tires = faster speedo reading.
Old Nov 1, 2008 | 03:43 PM
lww's Avatar
lww
Head Muckraker
http://www.miata.net/garage/tirecalc.html
Old Nov 2, 2008 | 05:33 PM
pete8717's Avatar
I knew my speedo was about 5 off but does anyone know how to actually change the speedo calibration so it reads accurate?
Old Nov 3, 2008 | 06:54 AM
Well... you have to calculate how many revolutions off it is from stock. Using that website L-Dub posted is probably the easiest way. Then you could either take the speedo to a shop willing to re-calibrate it for you (they will likely charge a nice bit of $$$cash$$$), or get a speedo tranny cog that will bring it closer to the real reading...
Old Nov 3, 2008 | 08:38 AM
pete8717's Avatar
How could I tell which cog to get?
Old Nov 3, 2008 | 08:48 AM
Well, the smaller tires are acting as a higher ratio diff (If I'm thinking this out correctly). So... you could try to find a 4.11:1 cog (pretty rare actually). I think the easiest solution would be to get the right size tires.
Old Nov 3, 2008 | 08:54 AM
pete8717's Avatar
I did not know that. Ok thanks. In december i'm puttin on my new rims and according to that lil conversion page my speedo will still be a little off. It will only be about .1 off so I ain't worried about it. I'm going with P205/ 65R15 and that is the closest I will get
Old Nov 3, 2008 | 05:39 PM
260zturbo's Avatar
Stupid Hurricanes...
http://atlanticz.ca/zclub/techtips/d...tial/index.htm
4.11:1
* 720 4X4 6/83 to 12/85 - R180
* 200SX Turbo 1985 to 1986 - R200
* 200SX Turbo 1985-1998 -R200 (Canada)
* 200SX Non-Turbo's 1984 to 1988 - R180
* Ring gear is stamped with 37:9
also found this pretty cool website
http://www.nicoclub.com/Greg/ratios.html
mckenzig
Aug 24, 2007 03:33 AM
flightforlife07
Jun 13, 2007 09:04 PM
kenneth
Oct 17, 2004 04:29 PM
ratedZ
Apr 24, 2004 12:56 PM
ShadWarr1
Jan 24, 2002 07:44 PM
