Rubber boot between AFM and TB....
Old Jan 11, 2005 | 05:35 PM
MacRocker's Avatar
I have a 1980 280zx with the non-turbo L28. It has a rather old and cracked rubber boot between the AFM and TB. I got a replacement boot from the z store. The new boot has one small port coming out of it which I believe a hose goes to the air regulator. On the original boot, another port was rigged (with silicone and metal tube) that led to a hose which connected to the PCV valve on the valve cover. My service manual doesn't have anything specific about this boot and hose/hoses connecting off of it. Does anyone know anything about this rubber boot and the hose/hoses that come off of it. Where does the air regulator get its air feed, and where does the PCV hose connect to? A detailed picture of the engine compartment of a 1980 280zx would be helpful, but I can't seem to find one.
thanks
dp
Old Jan 11, 2005 | 07:00 PM
DoTheDrew888's Avatar
Here is a picture of my '83 engine, it should be basically the same as yours. Let me know if it helps.
Old Jan 12, 2005 | 10:29 AM
MacRocker's Avatar
Thumbs up Rubber boot between AFM and TB....
Thanks, your picture helped a lot. Now it seems, I might have a 83 motor in my 80 280zx, and the proper rubber boot for that year is no longer available from motorsports. I guess I'll have to modify the new one I have for the 1980 model.
Old Jan 12, 2005 | 08:04 PM
RodMoyes's Avatar
Doesn't post much...
All of the vacuum system is different in 1980 cars depending on wether it is a California car or a Federal car (smog wise). Which car is yours? Mine is an '80 Federal car... so I might be able to help you if yours is as well. If you aren't sure... the easy way to tell is to see if you have a second air hose running from the air cleaner box back to a small box next to the AFM. That is the "air induction valve" and is only on 1980 Federal model 280zx's.
Rod.
Majere
Aug 29, 2013 06:04 PM
runningjalapeno
Aug 16, 2009 05:33 PM
jmmorriso
Jul 12, 2007 08:50 AM
machsound
18
Dec 28, 2006 10:19 AM
Brad
Oct 24, 2002 01:32 PM
