Rebuild Project
Ok I have a small (might be big) issue. When I shift from first to second at a high RPM (Or at lest over 3K) It will kick the shift hard out of first making the entire car thud quite hard also like I hit something. the higher the RPM the harsher it is. I did this at yellow line and I thought my trans exploded out from under my car. and it only does it from shifting out of first.
almost all clutch related stuff is knew and adjusted properly. trans is at the right fluid level and yes I am using the clutch when I shift (duh) Anyone have any ideas what the hell is going on?
Okay.
On another note, I've seen a few people with subs installed into their spare tire cover and I'd really like to know how you guys mounted it so it wont vibrate the entire panel loose and rattle like mad. I just installed a sub today and its sitting right in the middle of the hatch, and even tho I love the sound I hate where it is (Its only a 300W btw, I do like my hearing)
And I'd also like to know how to get the Z32 seats to properly fit into my 280ZX while still being able to put them back into my 300ZX later once I get it fixed. Last time I tried it the stock 300ZX rails barely fit on the front bolts but where anywhere near close on the rear bolt/stud. I'm about to take the seats out of my 280ZX and burn them. I really hate them.
Would that work and still be safe?
They do sit a little bit taller then the very worn lopsided low backs I had, but I got used to it real quick. Mine was a partial bolt in with some tweaking. Just gotta sit and
and
and
then some
and
and it'll come together...
Ah ok lol I wasted 3 days on a racing seat for my 280ZX and once I got it finished. the door wouldn't shut.... So I'm gonna try to not waste so long a time to make a mount that doesn't work lol
I started the figure out a way to pull the seals out of the glass on my spare hatch. But I measured it before I got to far along. Doesn't matter if I get it off it wont fit!
PS: Why is the 2+0s glass and hatch BIGGER then the longer 2+2's hatch?
I see. Oh well.
And winter has hit full force in fernal finally and I learned a few new things about my Z.
IT HATES WINTER!
It barely even started this morn and I had to let it warm up a little bit before I could even get it to rev enough to drive w/o backfiring and dieing
And to start it I have to keep cranking it while slightly pushing on the gas or it wont start all all and just keep spinning.... ugh.
IT HATES WINTER!
The one place I didn't check for a new heater core. actually had one for $65....
Now to find the cheapest place for the heater control valve and all the lines. I expect to have a heater working like 2 weeks from now lol
I swore I put up an wanted ad for one. Oh well. Right now I'm saving up for the lines and for the control valve. Everything was leaking in my heater system. I was always wondering why I needed more coolant every so often.
BTW On the side of the block where the heater lines are. What is that brass thing that takes the line from the front of the block and splits it to the heater core and back into the engine head? Cuz mine is leaking and I want to know what it is to find a new one (or delete it if it isnt needed)
Trailer Hitch
Sorry, I haven't read the entire thread yet...have you found a trailer hitch? If not, search EBay "300zx trailer hitch" to find the model number and buy it somewhere less expensive. I pull a pod trailer behind my '79 280ZXR. Tows fine but tends to float at about 90.
