Purchasing advice
Old Mar 6, 2014 | 01:53 PM
ohsemix's Avatar
Purchasing advice
Ok so my 1980 280zx break booster has a rust hole and i found one used on ebay for $55 free shipping. It looks good but it says it has 235000 miles on it so what do yall think. Is it better to buy the rebuilt one from rockauto for $90 or go with this used one.
Attached Thumbnails Purchasing advice-break.jpg   Purchasing advice-break-2.jpg
Old Mar 6, 2014 | 02:09 PM
Go with the one that DOESN'T have a rust hole in it.
Old Mar 6, 2014 | 03:18 PM
ohsemix's Avatar
that answer was almost as bad as if you had answered me with another question. But at least it makes sense.
Old Mar 6, 2014 | 04:31 PM
Sorry... that sounded rude. I tried to get a few posts in before leaving work.
For $55 you can get a used one, or for another $35 you can have a cleaned up, checked for leaks, reman. I'd go reman for peace of mind...
Old Mar 6, 2014 | 07:47 PM
ohsemix's Avatar
yeah i rather pay 35 more to be sure it will actually last. thanks for the advice
Old Mar 7, 2014 | 07:26 AM
PredatorZ's Avatar
Reman
Nismo is right, go with the checked out part, an old dodgy part could just end up costing you twice. Also, many different parts can be swapped over and the braking system has many interchangeable parts, if I recall I recently read a nismo writeup about changing the master cylinder and booster on a s130 280zxt if I recall, so you might look that direction too.
Old Mar 7, 2014 | 02:17 PM
ohsemix's Avatar
yeah i was wondering if there is a thread for a break booster swap. Because the 280zx one is hard to find and only rock auto has them for less than $100. And also i found out it was the shaft in the middle of the break booster that was letting air out making it feel like the booster had a hole. The shaft is real crusty i guess that why it lets air out
Old Mar 10, 2014 | 07:53 AM
I swapped an 82T booster into my 76 S30 (pics in post #24): https://www.zdriver.com/forums/240z-...c-heavy-30516/
The 280ZX has two booster versions: 79-81 and 82-83. One has the master mounts vertical, the other has them horizontal. So if you want to swap boosters, just make sure you use the master for it as well.
cwarren99
Jun 26, 2013 12:20 PM
BillyJackLib
Mar 15, 2013 07:58 PM
mooredb
Jun 17, 2010 08:22 AM
baj
Nov 20, 2002 12:40 PM
happyattacks
Aug 5, 2002 04:25 AM
