Power Prolbems
Old Feb 20, 2013 | 05:39 PM
yeahididthat's Avatar
Thumbs down Power Prolbems
When my car begins to redline and about 5-7,000 rpm my dashboard beings to make a buzzing noise. It will not stop making that noise until either I turn the car off, or while my car is shifted into reverse. My door ajar and parking brake warning lights will illuminate as well.
Also, I replaced my alternator because my voltage kept dropping gradually from the standard reading of 12 to eventually slowly dropping to about 6-7 volts when the car begins to run rough and it dies. But what I can do is redline the engine like above, and it goes right back to 12 volts and everything will work as it should except for my dash will buzz and the warning lights will not go off
Ever heard of this prolbem?
Old Feb 20, 2013 | 06:46 PM
#1: Why the crap are you running your motor up to 7k RPM's? Unless you have a highly modified motor, there is no need to run it past ~5500 RPM because peak hp is ~5200 RPM. And on the L28E n/a motor, it's pretty pointless to run it past 5k at all.
#2: So are you saying that even after you replaced the alternator, the voltage will still drop? The dash lights illuminating is a common sign of a dead alternator. Take your car to a local auto parts store and have them load test the alternator & battery. Also, the stock n/a alternator is rated for ~50amps and is worthless to replace with another stock one. Replace w/ a Maxima one or GM 1-wire.
Old Feb 20, 2013 | 08:13 PM
Post
I don't race my engine on purpose, it happened when i thought i had the car in gear when i first experienced the buzz
i have a duralast alternator inside it but the same battery
Old Feb 20, 2013 | 08:14 PM
also after installed the new alternator i had the old one tested and the machine said it was a good one
Old Feb 20, 2013 | 08:22 PM
Old Feb 21, 2013 | 03:18 PM
yes the volts still drop
unless i rev the engine, then i have to deal with that dam buzzing
3riCJbOi
Jun 28, 2012 10:13 AM
audiofreak97
Nov 19, 2010 06:20 AM
bardabe
Other Cars
Jan 30, 2009 11:13 AM
JohannB
Nov 21, 2003 05:54 PM
turborocket
Apr 29, 2003 07:15 PM
