(possibly) New guy here
Old Jul 30, 2010 | 11:21 PM
67goatman455's Avatar
Well i'm looking at picking up an 83 5 speed turbo 280ZX 2+2 for my new daily driver. Is there anything i need to pay close attention to when i go take a look at it in a few days? the guy said he had daily driven it for 3-4 years so i'm pretty sure its going to be reliable. Also it looks pretty stock besides what looks like a super sweet PVC intake tube and aftermarket filter
thanks guys!
Old Jul 31, 2010 | 08:44 AM
rogerz's Avatar
Grumpy & Helpful
rust in the rear under carpet fairly common. spare tire wheel well rusted out. digi dash climate control usually busted by now. does it wander the road like a drunk when on wavy pavement then needs ball joints, tie rod ends and bushings. be sure all the lights and stuff works before you hand over the money so you don't have to post like the guy who bought one and then asked how to get the lights working after he got it home. fender under the battery box eaten out by acid. Battery cables severely corroded and/or those one size fitall clamp on connectors. slipping clutch. sticky tranny.
Old Jul 31, 2010 | 09:28 AM
i found a sticky on here about what to check for when buying a new car. (which i cant link apparently because im a newbie) very helpful! he did say the parking brake didnt work, but apparently its a common problem.
and thank you rogerz!
Old Jul 31, 2010 | 11:40 AM
rogerz's Avatar
Grumpy & Helpful
parking brakes are not a common problem on the s130 but they are on the z31. could just be an adjustment problem. Also pull the oil filler cap with the car idling. If it runs rougher that is good. If it stays the same means (probably) you have vacuum leaks to fix. again look at all things that operate electrically, wipers, interior lights, washer etc. they are usually time consuming to track down and repair.
Old Aug 1, 2010 | 03:47 PM
KHCreason's Avatar
Take pics of the intake! I need ideas on how to pipe mine
please
GasMan
14
Jan 29, 2011 09:39 AM
Awgy
Jan 11, 2010 10:05 PM
Korsair
Oct 2, 2009 12:49 PM
lyonmt
Nov 2, 2008 05:50 PM
WhtFairLadyZ
Mar 21, 2005 06:06 PM
