Driving me FLIPPING NUTS
Old Jul 25, 2010 | 11:29 PM
Racer_ZX's Avatar
Angry Driving me FLIPPING NUTS
Hope someone out there can help figure this out....
My '81ZX will start idle and run for anywhere from 10 minutes to 10 hours. Depending on it's mood of the day. I've replaced all the relays checked the fusable links replaced fuel pump checked timing and no better (or worse) results. I have a Kameari(spelling?) dizzy and ignition module in it. It's ran fine for 3 years with no problem. One day it stalled while doing 70 then picked up. A couple weeks later it does it again then more often to the point I won't take it out anymore knowing it's going to die multiple times before I get a mile.
Ideas?
Suggestions?
Gasoline a match and hotdog roast over it's burning carcass?
Old Jul 26, 2010 | 12:16 AM
BlueKitsune's Avatar
Intrawebz Wizard
Corrosion on some connectors somewhere can do that. ECU starting to give out will do that too. Is everything clean and hooked up right along with no vacuum leaks and the valves adjusted properly? And your oil/coolant isnt milky? also do a compression check just to make sure its not mechanical.
Old Jul 26, 2010 | 02:36 AM
WanganDevilZ's Avatar
The Emblem Thief y0!
Originally Posted by Racer_ZX
Suggestions?
The only reason why your house is not on fire is because you did not list where you lived...
Smart man...
Old Jul 26, 2010 | 09:26 PM
Make sure the MAF connector is clean/tight and the retaining clip isn't missing as well. Check all the engine connectors for corrosion, etc....
Old Jul 27, 2010 | 12:24 AM
Intrawebz Wizard
AFM actually but same diff
Old Jul 27, 2010 | 09:13 PM
Doh! I was thinking AFM.... does that count? :P
Flapper - not the heated wire
Old Aug 1, 2010 | 08:13 PM
duckyz's Avatar
Check the CHTS on the passenger side of the motor. It's a little connector just under the #5 spark plug, close to the oil filter. Make sure the connections are clean and that it had a good connection when mated up.
Crashcourse
Jun 24, 2015 08:34 AM
omniserv
May 23, 2011 08:09 PM
KeithDigital
Jul 8, 2009 08:49 AM
tonsoffun300zx
Oct 27, 2007 11:22 AM
GARYZ240
Feb 4, 2005 12:43 PM
