Pics of my soon to be 1983 280zx
Old Sep 19, 2006 | 06:00 PM
  #26
FubarI33t's Avatar
i tryed to dell somethign on e-bay before. And they kicked it off. FCC laws don't like you selling Linear's on there. Dang. i could of got 400-600$ for it too
Old Sep 19, 2006 | 06:14 PM
  #27
whats a linear?
Old Sep 22, 2006 | 11:31 AM
  #28
Okay big day everybody. Today the surgery starts, going to get the Z on jackstands.('83) And start working on it, will keep you informed.
Old Sep 22, 2006 | 06:32 PM
  #29
jfairladyz's Avatar
WildmaN needs his own blog here on ZDriver
Old Sep 23, 2006 | 07:01 AM
  #30
Allright quick update, before I crash for a few hours. The fuel tank swap was a success, and now I have something else under my belt. First time, I ever attempted this. It took me almost 5 hours, but I do not regret it. Anyway, getting sleep, then fuel, clean up contacts, connectors, and such. Check the fluids, fix the ignition switch. And give my "Smoke" a few turns. And hopefully I will hear it run. Will let you all know, as always.
Old Sep 23, 2006 | 08:58 AM
  #31
RodMoyes's Avatar
Doesn't post much...
Way to go WildmaN!!!
Rod.
Old Sep 23, 2006 | 07:52 PM
  #32
jfairladyz's Avatar
WildmaN is a machine. A robot in disguise (sorry, I couldnt resist )
Old Sep 23, 2006 | 08:59 PM
  #33
Well I burned today, so tomorrow, I will commence. I need to play doctor with a girl, I have been seeing for the past month. She is not feeling well, and I am bringing the pepto and sprite. So hopefully she can go with me to karoke tonight. So tomorrow, I will hopefuly get my Z to run. Will let you all know, and thanks for the comments, keep 'em coming.
Old Sep 24, 2006 | 07:49 PM
  #34
Allright update for all of you. I went through, and cleaned the plugs, and connectors and such. And got to hear it crank pretty healthy, it is a start. So now I need to figure out if I am not getting, air, spark, or fuel. So that is the next thing I need to troubleshoot, and figure out.
Anyway I have a question for all of you. On the ECU, I noticed a yellow, with red stripe, and a black wire. That is unplugged from the ECU, is that important. And where does it exactly go? I am going to look it up in my manual. But if anybody, can give me some insight on this, that would be great.
Old Sep 25, 2006 | 09:06 AM
  #35
I want an update on the kareoke and doctor.
Old Sep 26, 2006 | 06:34 AM
  #36
Ha Ha you are too funny Bleach. I went over to her place, and she took some Sprite, well a short while later, we were going out the door. And off to Karoke, and we had fun as usual. Keeping my fan club happy, especially her. Anyway hope that explains it for you.
And hey, what about that plug with the 2 wires on it? A yellow, with red stripe, and a solid black wire. Still need to know, if I need it for the ECU. Because that is what they are coming out of. So I can figure out how to get this Z started. So help me out guys, that would be great.
Old Sep 26, 2006 | 07:37 AM
  #37
FubarI33t's Avatar
Wildman, i asked this months ago. Every one has this plug, But none of them are Ever hooked up. I would not worry about it. cause it really don't do nothing at all. My black car start's and runs with out this hooked up. And i have never seen it hooked up on any Z.
Old Sep 26, 2006 | 07:40 AM
  #38
hey wildman is the black quite larger? as in the ground for the ecu? and the other wire might just be that sensor light wire thts supposed to be unplugged, usually things are supposed to be plugged in if the connectors match. id just plug the black one in first and try it, then the yellow with red stripe, it wont blow the ecu, it would more likely blow a fuse, or ust not work at all
Old Sep 26, 2006 | 08:02 AM
  #39
FubarI33t's Avatar
umm, yeh. That bigg single wire is a ground. but those two small ones don't go to anything. Just wrap the two(they join to one connector) around somthing. But that bigg one Has to be pluged up.
Old Sep 26, 2006 | 08:49 AM
  #40
I just put a turbo engine in my car and left those plug open. seems to work fine. you might try that...
Old Oct 1, 2006 | 09:06 PM
  #41
Well I worked on the Z Friday, and I now know, it is not getting fuel. I got it to run on carb cleaner though. So now I need to figure out why it is not getting fuel. I took the fuel line off the fuel filter, cranked and nothing, dry as a bone. Yes the fuel pump is brand new, and you can hear it working. So I also know the relay is good, I think it is a clogged line, or something to that effect.
Old Oct 1, 2006 | 09:15 PM
  #42
Clogged injectors?
With the rail still connected & injectors installed, turn it upside down on the intake manifold & crank the engine to see if the injectors spray.
Old Oct 1, 2006 | 09:38 PM
  #43
no, I mean no fuel coming from the tank at all. That is what I need to figure out, why I am not getting fuel from the tank. Sorry if I didn't clarify that correctly.
Old Oct 1, 2006 | 09:42 PM
  #44
Ah... I just need to read better. Start at the source then.... pull off the pressurized side of the fuel pump line & see if there is fuel at the pump. And this might sound TOO simple, but are you sure you got the + and - wires to the pump bolted to the right poles?
Old Oct 1, 2006 | 09:54 PM
  #45
Well they should be, but I can't check right now, too dark. What would happen if they are not right?
Old Oct 1, 2006 | 10:03 PM
  #46
Fuel pump would prolly be turning backwards, trying to suck fuel from your injector side of the line.
Old Oct 1, 2006 | 10:07 PM
  #47
Hmm.....Could be possible, I will check sometime this week in daylight. You may have something there bro' thanks. Will investigate, and let you know. That would be funny, if that is what is wrong with fuel delivery.
Old Oct 2, 2006 | 08:55 AM
  #48
jfairladyz's Avatar
^ I've actually done that before
Old Oct 14, 2006 | 05:22 PM
  #49
Okay well not much to update on my '83 yet. Been lazy lately, and don't like being ate up by mosquitos. I will probably tackle it again, this coming weekend. I really would like to get it runnning, but no big hurry considering, I have a great and reliable Z right now. Even though he leaks oil, and is running rich. Anyway will let all of you know, when I do more on my other Z.
Old Oct 22, 2006 | 08:25 PM
  #50
Still nothing, not motivated right now. More worried about why my '82 runs rich. Sometime eventually I will get around to messing with the '83. Just not at this present time. I will keep you all updated, on it though.
