Need help Passing smog
Old Jun 1, 2013 | 01:17 PM
TangerineKnight's Avatar
Recently Acquired a 1983 280zx and it had been sitting for a while. I took it to get smog checked and it was pretty bad. I got a new catalytic converter, and even had somebody repair the EGR system, and now only the NO level is just a little too high. Any suggestions would be greatly appreciated.
Old Jun 1, 2013 | 09:25 PM
pnoyslimm's Avatar
NEW O2 Sensor, spark plugs, clean throttle body, maybe a new muffler??? or you could have broken or disconnected vacuum lines??
Just my 2 pennies, i had never gone through a smog test. but this is what are some of the things ive heard could help fix passing smog....
Old Jun 2, 2013 | 08:00 AM
Welcome to ZDriver!
How long is "a while" ? Does it still have old gas in it?
What was "pretty bad" ? Details...
What did they do to "repair" the egr system? Details...
How much is "a little too high" ? Details... scan the emissions readings please.
Old Jun 2, 2013 | 01:36 PM
Thanks for the responses.
this is the old smog check.
That is the newest one.
Quite honestly i'm not sure how long it was sitting for. I put a little gas in it, but there is probably some of the older gas in the tank.
As far as the EGR system, the mechanic told me it was not working, and that he had repaired the system.
Old Jun 2, 2013 | 08:16 PM
  1. Get rid of the old gas.
  2. Check timing.
  3. Check / read / replace spark plugs (NGK's only!).
  4. Check / replace spark plug wires, cap, rotor.
  5. Check / change oil.
All the stuff you SHOULD do before taking a newly acquired car to emissions.
Old Jun 3, 2013 | 12:11 PM
Thanks for the advice, I filled it up with gas, drove for about 20 mins at highway speed and then it passed.
Old Jun 3, 2013 | 12:49 PM
+1 on the NGKs. It's funny that after 40 years of people messing around with spark plugs for the L24/26/28 and the best plugs you can get are the one's Nissan said to use from day one
60to0
Feb 28, 2013 06:51 PM
blackpearlz
Jul 28, 2009 10:35 AM
918v_zxt
Jan 30, 2008 03:29 AM
batwood77
Jul 20, 2004 07:01 PM
CrazyLotusTT
Dec 1, 2002 10:16 PM
