My Z is running better!!
Old Nov 25, 2006 | 07:46 PM
Oh yeah, I finally got around to putting the test pipe in place of my gutted catilytic convertor. And wow what a friggin' difference! My Z has better pickup, and is louder than before. I can't believe the power loss, I had with the gutted cat on there. I had no idea, it would make that much of a difference. But man was I wrong on that one.
I also retightened my oil pan bolts. They were loose, and I noticed heavy oil spots toward the front of the motor, at the bottom. I am crossing my fingers, that is not the front seal. And it is just because the pan bolts were not tight enough. Maybe after so many miles, the gasket set in that, it needed to be retightened. I hope anyway.
I also investigated my e-brake, and found out that only the right rear wheel was hooked up. And it was sticking, so I am not using the e-brake, until I get a new one. It looks like the left rear wheel hookup cable broke off. I guess anyway, not sure. Well there you have it, I am glad, I finally changed out the test pipe, what a difference.!
Old Nov 25, 2006 | 08:45 PM
Werd! Sounds like ya got a lot accomplished today. The 280zx e-brake cable is somewhat prone to freezing up. Sometimes you can free it up by spraying some penetrating oil in each end & move it back and forth... but sometimes ya just gotta replace it.
Old Nov 25, 2006 | 11:18 PM
good to hear wildman, like the new sig pic too, those wheels look dope. i had to lube the ebrake cable too, they want 240 bucks a side up here in canada, so i chose a hour of my time and some penitrating oil, good as new. and yeah, having a catalitic is not great for power, if you get a high flow one its o.k, but they usually dont get you thru the check. best to have a test pipe like you do and change it out when needed.
Old Nov 26, 2006 | 07:55 AM
CraigS's Avatar
You saying this gets me so hyped, I just dropped my car off at the shop to get a test pipe put in AND I'm getting it done for FREE!!!!! WOOT!!!!
Congrats on the fresh ride!
Old Nov 26, 2006 | 08:14 AM
z-hag's Avatar
Queen of Yachts
i did that to my chitty luv truk in 1979--the truk was a 1975, stuk cat--the convertor was still on the car--the pipe went stroight thru it!!!!
BIG difference--i liked to keep the pipe because of the occasional visual inspection.
stuck cats donot only hurt performance--they cut years off the life of the engine
Old Nov 27, 2006 | 08:46 AM
wreckedj30's Avatar
No Club Love
hmm, good job. I'm thinking of puting the muffler from the j30 on my car, cause i have no exhaust, just a cat then nothing. I wonder if there the same diameter and what not, donno. should i use the cat also. nawww, screw the ozone layer.
Old Nov 27, 2006 | 08:49 AM
No! Just need 2.5" pipe & a performance muffler for your Z... no J30 econo muffler.
WildmaN
Feb 25, 2007 08:57 PM
EZDUZIT
Jul 5, 2006 02:03 PM
Nemesis280zx
Jun 29, 2006 02:57 PM
beez
Apr 30, 2006 01:17 AM
Soup80
Dec 14, 2003 01:53 AM
