My 1979 280zx
Old Jul 4, 2010 | 01:21 PM
evandubya's Avatar
Primer Grey FTW!
My 1979 280zx
I bought this car yesterday I'm going to restore it
so far i've pulled the gas tank and gutted the interior tomorrow I'm going to clean out the tank and fuel lines then try to start it.
Old Jul 4, 2010 | 06:40 PM
Welcome to ZDriver!
I fixed your picture links. The car looks good!
Old Jul 5, 2010 | 10:42 PM
evandubya's Avatar
Primer Grey FTW!
1979 280zx no electrical power
Hello, my name is Evan, I'm a new member. I just bought a 1979 280zx, its in pretty good shape except for the electrical.
I have power to the starter, fusible links, ignition relays, but, when I turn the key nothing comes on at all. I'm afraid its the brain, but, I don't know how to check it any suggestions would be greatly appreciated
Thanks
Old Jul 7, 2010 | 10:18 PM
evandubya's Avatar
Primer Grey FTW!
I got the electrical fixed, when I replaced the groung wire to the battery I didn't realize it was connected in two spots with another wire behind it. But now my fuel pumps out, I sprayed some starting fluid and turn it over it and it fired up for a second so all I need is the fuel pump
Old Jul 8, 2010 | 03:47 AM
^ That's good, yeah a fuel pump wont set you back too much. And pretty easy to change. Good luck, and keep us posted.
Old Jul 8, 2010 | 09:36 AM
after market split sunroof. car looks to be a good starting point
Old Jul 8, 2010 | 11:09 PM
evandubya's Avatar
Primer Grey FTW!
_
cool... I assumed it was original, its made by Le Van sport top
Old Jul 8, 2010 | 11:11 PM
evandubya's Avatar
Primer Grey FTW!
Turns out I don't have power coming to the fuel pump,so now I'm chasing wires again.
Old Jul 8, 2010 | 11:59 PM
mighty's Avatar
Good luck to you Evan and congrats to purchase a car.
Old Jul 22, 2010 | 04:33 PM
evandubya's Avatar
Primer Grey FTW!
got it running it sounds good, minus the holy muffler. Bought a parts car, starting to go through it I'm going to restore it
Old Jul 27, 2010 | 05:16 PM
evandubya's Avatar
Primer Grey FTW!
does any one have a turbo for sale and how much ( i can make a exhaust header)
Thanks
Old Jul 28, 2010 | 02:06 AM
Thanks
Wow, I wish I had one. So you are saying, you can make a header for a turbo L28? If so, that would be sweet.
Old Jul 28, 2010 | 09:54 AM
WanganDevilZ's Avatar
The Emblem Thief y0!
Lol, I think what he means is he can make a turbo flange. Take the N/A/ header and put a little square exit with 4 bolts on it...
I've seen it done. Not personally, but i've lurked import threads till the wee hours of the morning to see alot.
Old Aug 1, 2010 | 10:16 PM
evandubya's Avatar
Primer Grey FTW!
i can make a header
Old Aug 1, 2010 | 10:45 PM
Nice...be sure to post progress and pics.
Old Aug 2, 2010 | 07:59 AM
MurphyEF's Avatar
Glad to see I'm not the only one with that sunroof. I just have to get some new seals for it, as it tends to rain quite a bit up here in WA. Good starting point, mate!
Old Aug 12, 2010 | 09:40 PM
evandubya's Avatar
Primer Grey FTW!
my parts car is taken apart. i have a few things to do then i'll get a temporary registration and insurance drive it around for awhile make sure the engine a tranny are good.
Old Sep 19, 2010 | 10:33 PM
evandubya's Avatar
Primer Grey FTW!
started taking apart the parts car engine. I need to measure the cylinders but it looks like i'll just need the re-ring bushing kit. Do the turbo piston rings fit a 1979 engine it has the dished pistons. I picked up a rebuilt turbo head P90 for $100.
Old Oct 16, 2010 | 01:17 AM
evandubya's Avatar
Primer Grey FTW!
parts car is apart everything but the unibody is in my shed. I've started making an intake manifold and custom tail lights. right now I'm cleaning the rust off the roof and between the windshield and hood, a few holes that i have to braze which is slowing down everything else. i also have the dash out so i can easily change out the butchered wires.
been working on my roof haven't had much time for anything else, but once that is done i should be able to get it drivable. then i can concentrate on building the engine out of the parts car and adding a turbo.
Old Oct 25, 2010 | 09:13 PM
mrprofile's Avatar
I feel your pain, i'm down in Tacoma and my sunroof leaks too
Old Nov 14, 2010 | 07:17 PM
evandubya's Avatar
Primer Grey FTW!
more pics
[IMG][/IMG]
tail light mock up
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
p90 head I got from pick and pull
[IMG][/IMG]
Old Nov 14, 2010 | 07:32 PM
evandubya's Avatar
Primer Grey FTW!
I ordered most of my parts waiting for them to come in.
Old Dec 5, 2010 | 05:25 PM
evandubya's Avatar
Primer Grey FTW!
[IMG][/IMG]
Got my air dam mounted and my little brother and I are are putting on the Bondo so I can get it painted.
Old Dec 5, 2010 | 05:31 PM
evandubya's Avatar
Primer Grey FTW!
I also got my cap, rotor, plugs, and wires installed
Old Dec 12, 2010 | 11:02 PM
evandubya's Avatar
Primer Grey FTW!
Friday and today my best friend and I spent 15 hours sanding we finally got to put on some more Bondo and sand it down. The roof is done and the passenger rear quarter panel is close.
The good news is, I'm learning how to Bondo, its just taking longer than I want.
