Major Problem...
Old Dec 18, 2007 | 11:39 AM
satisfied's Avatar
Talking Major Problem...
So our 1980 NA 280Z's idle stays in the 1400 to 1800 range even while sufficiently warm. We have a feeling it has something to do with the coolant temperature sensor, as it would not be able to recognize when it was warm enough to drop the idle. Any merit to this idea, or could it be something else? We already tried the idle screw, timing retard/advance doesn't yield any results either, we replaced the air controller valve, we already checked the spark plug gaps, we have the chilton manual, and out EGR isn't where it is supposed to be, we seriously cannot find it, we already tried the throttle valve switch as well, what could be wrong with our unfairlady?
This is a pretty sweet smiley
Old Dec 18, 2007 | 11:46 AM
Welcome to ZDriver!
Sounds like a vacuum leak if all else has been checked and is proper. The egr is located at the back of the intake manifold by the firewall & brake master cyl. Chiltons sucks... buy a Haynes.
Old Dec 18, 2007 | 11:49 AM
satisfied's Avatar
Welcome to ZDriver!
Already checked for a vacuum leak, but we'll check for the EGR and see if something is amiss. I know Chilton sucks now, lol, we've been chilton customers forever.
Old Dec 18, 2007 | 11:50 AM
could be that the throttle linkage is not letting the plate close or a small hose is unplugged possibly on the bottom of the throttle body.
welcome
Old Dec 18, 2007 | 11:52 AM
satisfied's Avatar
welcome
Checked checked and checked, spraying starting fluid around the area, no surge. Thanks though. anyone know about he coolant temperature sensor?
Old Dec 18, 2007 | 11:57 AM
There are two...
One for the temp gauge, and the other is a thermotime switch for the intake / injector fan. They don't have anything to to w/ controlling the idle.
There's only so many things that will affect idle:
-vacuum leak (oil fill cap, vac lines, oil dipstick, etc)
-mis-adjusted idle screw
-mis-adjusted AFM
-mis-adjusted timing
Old Dec 18, 2007 | 12:17 PM
satisfied's Avatar
There are two...
-mis-adjusted AFM
Hrm. This is a shame, we'll try all of these over again, and it's raining so we're not about to move this classic beast to the working garage. I'll keep this thread updated.
Just to let everyone know, it only has 54k miles on it, and after we get the idle under control and paint it, it's going up for sale.
Old Dec 18, 2007 | 12:28 PM
RodMoyes's Avatar
Doesn't post much...
There are two...
-mis-adjusted AFM
A bad Fuel Pressure Regulator can cause a high idle as well...
OGG
Old Dec 18, 2007 | 12:30 PM
satisfied's Avatar
OGG
Adding to the check list.
What kind of rims are those?
Old Dec 18, 2007 | 12:37 PM
RodMoyes's Avatar
Round.
Rod.
Old Dec 18, 2007 | 12:40 PM
satisfied's Avatar
Round.
Rod.
so, got a link to a site or something?
Old Dec 18, 2007 | 03:28 PM
lol, round.
also, air regulator can cause high idle if its stuck.
Old Dec 18, 2007 | 05:47 PM
satisfied's Avatar
lol, round.
Alright guys we still can't find the EGR, can someone post up a pic? There's supposed to be a tap for the EGR control on the exhaust manifold, it's not there, also the EGR is nowhere near where it should be, in fact, it's absent. WTF?
The car is bone stock.
It's not a vacuum leak. If we unscrew the oil cap, however, the idle will cool down to 700 RPM, right where it's supposed to be!!! WTF?
We checked the idle screw again, even fully down will make it idle at 1400-1800 RPMS.
It's not mis-adjusted Timing as it only has 54k miles and was never messed with. We checked it anyway.
We'll check the Fuel Pressure regulator...
What is an AFM?
This just in, we're looking over at the Canadian model schematics and it is also missing the EGR, could it be that somewhere along the line someone replaced the Intake and exhaust manifold with outside of California parts? It's always been a California car, but seeing as how it is missing the EGR taps and unit, couldn't it be possible that they were swapped with out of sate/country parts and the ECU to accompany the change was never plugged in? It might seem out there, but it's possible.
Old Dec 18, 2007 | 05:59 PM
entropy31's Avatar
The Cake Is A Lie!
PCV maybe?
Old Dec 18, 2007 | 06:01 PM
satisfied's Avatar
PCV maybe?
Checked and clear, open/closing with no problem.
Old Dec 18, 2007 | 06:23 PM
all ZX's had a EGR, so if your doesnt, some one changed your exhaust and intake manifold already. it would be a large, circular looking selonoid (similare to a mushroom shape) on the very top back portion of you intake manifold, IMPOSSIBLE to miss. IM-F'ing-POSSIBLE! lol. so if you for sure dont see it, then its not there. there's no tricks in this game.
Old Dec 18, 2007 | 07:26 PM
Attached pics... N42 non-egr intake. P79 egr intake ( egr is circled in yellow )... courtesy of ICICE's cardomain page.
AFM = Air Flow Meter... the flap door box between the air filter & throttle body.
Attached Thumbnails Major Problem...-manifold3sm.jpg   Major Problem...-336708_14_full.jpg
Old Dec 18, 2007 | 07:40 PM
satisfied's Avatar
Lol, we checked the AFM without any knowledge it was called an AFM.
Yeah, we have that N42, no EGR could my EGR/ECU theory be causing us a bad idle?
Old Dec 18, 2007 | 07:58 PM
What theory is that??? The ECU doesn't control the EGR on the non-turbos... vacuum from the intake does. And you apparently don't have an EGR, so that wouldn't be a prob anyway.
How about posting a pic of your intake manifold for us... then we can SEE what's going on.
Old Dec 18, 2007 | 08:28 PM
RodMoyes's Avatar
I have lots of links... (EDITED)
OGG
Old Dec 18, 2007 | 08:41 PM
(EDITED)
OMG LOL WTF ROFL!!!!!111!!!111!!one!!eleven!!!11
That thread is bookmarked.
Old Dec 18, 2007 | 08:45 PM
satisfied's Avatar
Sure when the sunlight comes back.
as for sarcastic jack ***.
Your thread performed a malicious action, gj, isn't there some sort of penalty for linking to sites with potential danger?
Old Dec 18, 2007 | 08:49 PM
eh? what was the danger? worked for me... you got firefox?
PS... I think E will get a kick out of that thread. The computer tower is the best part...
Old Dec 18, 2007 | 08:50 PM
satisfied's Avatar
It was an unauthorized insertion of file through port 80 via some Firefox plug in, which is probably a virus or trojan of some sort.
Old Dec 18, 2007 | 10:15 PM
duowing's Avatar
NisTuner
I wonder if he even has an air regulator and such. Assuming the intake has been switched.
