Intro for my 81 S130
Old Jan 7, 2013 | 03:57 PM
  #26
ineednewtires's Avatar
<object width="853" height="480"><param name="movie" value="http://www.youtube.com/v/f69MUHfcJ_o?version=3&amp;hl=en_US&amp;rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/f69MUHfcJ_o?version=3&amp;hl=en_US&amp;rel=0" type="application/x-shockwave-flash" width="853" height="480" allowscriptaccess="always" allowfullscreen="true"></embed></object>
Old Jan 7, 2013 | 06:34 PM
  #27
And the Bettle pwnz...
Time to upgrade that clutch and install an intercooler.
Old Jan 7, 2013 | 06:39 PM
  #28
Clutch - do it!
Old Jan 7, 2013 | 10:05 PM
  #29
Got a new clutch/flywheel combo awaiting to be installed, got an intercooler from a friend and just need some piping now!
Waiting on school grant to come in lol!
That beatle on a stage 1 tune with stock intake/exhaust makes about 268 at the wheels lol..
Old Jan 11, 2013 | 09:22 PM
  #30
Random pictures as it's misting outside.
Looks stock amirite?
Got my intercooler mounted.
I wanted it to be sneaky so no one can see it from a distance.
It's not bolted up completely just yet.
Old Jan 12, 2013 | 05:31 PM
  #31
Ducting will make a huge difference in how your intercooler works (and your radiator!)
Consider running your air filter outside of the engine bay. Why draw in hot air from the engine bay when you can get cool air from outside - improves the efficiency of your intercooler system.
Old Jan 13, 2013 | 09:51 AM
  #32
It's been running swell even during yesterday's heat of 80+ degrees and todays 40 degrees..
She never gets hot and the stock clutch fan draws enough air anyways
Old Jan 14, 2013 | 06:57 AM
  #33
Hmmmm just wondering about spark plug gapping.
Bigger gap is capable if I have a stronger ignition system right?
I'm running .032 right now from just reading old threads on here
Would I be safe to run .046-048?
Thanks Cause I know .044 is stock so going down is kinda weird lol
Old Jan 14, 2013 | 07:13 AM
  #34
Yeah, there's no sense in running a smaller gap than stock if you have aftermarket ignition. Gap it!
Spark Plug Gap
Old Jan 14, 2013 | 07:16 AM
  #35
Haha I really have no idea why I decided to gap it smaller to be honest!
Thanks for the link
I'ma go gap the plugs whenever I get un-lazy :P
Old Jan 14, 2013 | 10:55 AM
  #36
For whatever reason I thought down-sizing the gap was good, well it was nice and all but my low end suffered crazy at .032..
Regapped at .048 and holy moly the car has low end and extremely insane top end now!
I love this car
Old Jan 22, 2013 | 10:09 AM
  #37
Car is running very well and what not. Boosting at 5-8 depending if the clutch wants to hold or not lol
I round about 210-220 to the wheels because I raced my friends stock GTI VW which is rated at 230-ish
Anyways, I'm fixing to install my walbro 255 and was wondering if anyone kept that stock fuel dampener thing a mabob?
Thanks
Old Jan 24, 2013 | 02:44 PM
  #38
Does the GTI weigh the same as the 280ZX? If not there is no comparison for the HP...
Old Jan 24, 2013 | 06:36 PM
  #39
Give or take the GTI weighs roughly 3200 lb with my friend in it.
My car probably weights what 3k?
Not far off honestly.
But does anyone know whether I keep the fuel dampener if I install my 255? Still waiting for an answer.
Also I threw in some Castrol 10-40, **** Royal purple for the price.
Runs amazing, smoother even now.
Old Jan 24, 2013 | 10:37 PM
  #40
Last time I weight myself and almost a tank of gas in the 280ZX loaded with T-Tops, AC, etc was 2800lbs - that's at least 400lbs difference there...
Keep the damper - why not?
Agreed on the oil - changing the oil regularly and the filter at the same time is 95% of the whole "what is the more awesomest" oil debat. Personally I like the Pennzoil Platinum (great VOA results, etc) bang for the buck. Use 5W30 if you can get it instead - provides better protection on cold starting....
Old Jan 25, 2013 | 09:51 AM
  #41
In Houston during summer it never drops below 70 degrees :/
I'm being optimistic because it's moreover around 80 degrees >_<
I'll change it back soon enough, if not would it be helpful to make a switch panel (which I plan to do when I upgrade the alt, electric fans, etc) and turn off the fuel pump and let the oil prime?
I don't know why not to keep the dampener lol I was just wondering, thanks!
Old Jan 25, 2013 | 03:40 PM
  #42
I don't think it's going to make any difference if the fuel pump is on or not. If you are cranking the engine over you're running it with electricity until the ignition/fuel system starts - the issue is oil getting to the top of the engine for the cams, etc. Unless you're running a pre-oiler system turning the fuel off isn't going to change how the system works getting oil to the top (eg the pistons/crank/cams, etc are turning regardless). 5W30 will just get it up there faster if its cold compared to 10W30 but give you the same viscosity at temp.
Old Jan 26, 2013 | 12:02 AM
  #43
Car's enjoying 10-40, gonna leave it like that.
even a friend of mine who runs junk-yard motors on 17 pounds of boost at 400+ whp says it's fine.
i'll go with whatever
anyways i'll leave y'all with this shitty run
https://www.facebook.com/video/embed...86868524692352
Old Jan 26, 2013 | 08:57 AM
  #44
https://www.facebook.com/video/embed...51367115813770
Another video of me xD
I got into the competition for FREE! because my friend’s “accidently’ payed for 2 drivers so…
ANYWAYS!
I ****ing got to tandem with my good friend and inspiration RUDY MARTINEZ!
I have never tandemed in real life before and I did EXTREMELY good on this track in this car, new chassis, more power, more angle..
I qualified FIRST! and finished 2nd because the run after this was *** D:
but omfg FUN!@!$#
https://www.facebook.com/video/embed...=4735256933168 second time tandeming ever xD
https://www.facebook.com/video/embed...51367081758770 inside view of that tandem D!
Old Jan 26, 2013 | 09:22 AM
  #45
https://www.facebook.com/events/3227...165653162649/?
some people were saying they can't see the video so use that facebook page to look at some!
Old Jan 26, 2013 | 09:31 AM
  #46
https://www.facebook.com/events/322763707836177/
Old Jan 26, 2013 | 12:21 PM
  #47
Old Jan 27, 2013 | 11:13 AM
  #48
Teaser of what's to come bitches! My wheels are getting dipped orange as well.
You get to see my "legendary" wall riding skillz yo.. no not really not in this video, in one of my qualifying runs I made 1st place due to it and won 2nd place.
This was the finals, I would've done better had my follow run not sucked ***.
but seriously no support?
Old Jan 27, 2013 | 11:14 AM
  #49
here's my legendary wall run says everyone
Old Jan 27, 2013 | 11:40 AM
  #50
Mad skillz yo! You and PurePontiacKid should have a duel. I think he's drifting some event in Vegas today.
